Old 06-04-2008, 12:23 PM   #1 (permalink)
90 day: 51.82 mpg (US)
Example of polyurethane foam car "sculpting"
For anyone considering DIY aero mods, you're going to love the DIY, low-tech method this guy used to goop up and sculpt an entirely new body on a Mercedes coupe using polyurethane foam.
Not apparently for aero, but the low-tech construction techniques should provide inspiration:
Many more pics:
http://englishrussia.com/?p=1949
Dr. Jerryrigger (08-15-2010)
Old 06-04-2008, 12:49 PM   #2 (permalink)
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
A good friend of mine acually used this very method back in the early '80s to form big honkin' fender flares on his '67 Mustang. Home depot spray foam, then 'glassed over the top. Turned out VERY strong, but maybe he over did it just a little as it was his first try at it. Placed well in some local car shows as well.
This is acually a plausible method.
Good design is simple. Getting there isn't.
Old 06-04-2008, 01:20 PM   #3 (permalink)
gamer_jim's Avatar
Reds' Bucket Mobile - '01 Chevrolet Cavalier 4 Door Sedan
90 day: 33.46 mpg (US)
Would this stuff be good for blocking out parts of the front grill?
How about making wheel skirts with it?
It would be nice, especially for the wheel skirts, to have something that could easily snap off/on without damaging the skirts.
Old 06-04-2008, 02:57 PM   #4 (permalink)
Probably OK for making a "grille plug", but not so good for wheel skirts, which need to have some structural strength and can only be so thick.
I could however see using this kind of stuff to build & shape the skirt area, apply a release agent and skin it with fiberglass - you end up with light, stiff skirts by making a polyurethane mold to lay the glass on.
Old 06-04-2008, 03:20 PM   #5 (permalink)
gamer_jim's Avatar
Not sure I follow you.
Are you saying make a base using the foam and then fiberglass over it?
Or just making a mold with the foam and filling the mold with fiberglass?
Any ideas on a clip-like thing to attach it to the car?
Old 06-04-2008, 04:03 PM   #6 (permalink)
Have you seen AndrewJ's thread and how he made his skirts?
See http://ecomodder.com/forum/showthrea...amics-312.html
Starting at post #3
Old 06-04-2008, 04:59 PM   #7 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
That's probably the method I'll end up using once I get moving on my body kit mods. Cheap, easy, and conforms to any shape you can carve
Old 06-04-2008, 05:00 PM   #8 (permalink)
Beefy
I can see placing a piece of cardboard behind the wheel well and then spraying foam all on top of it till it fills out the space. Then you could simply shave/sand it down even with the body lines. Next pull it out of the wheel well while still attached to the carboard. After that, lay some fiberglass on top of it, trim, sand, paint, and then remove all the foam from the backside and you have a perfectly shaped skirt.
Old 06-04-2008, 11:26 PM   #9 (permalink)
Pickup - '95 Nissan Pickup XE
90 day: 27.47 mpg (US)
If you put wire mesh inside, would that add enough strength? Maybe some window screen material.
Old 06-04-2008, 11:56 PM   #10 (permalink)
That's not a bad idea. I wonder how he finished the body though. I'm sure he didn't just sand & paint the foam. He had to "skin" it with something - and the same would be true for skirts made this way...
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
