10-18-2014, 04:24 PM
a few air dams from Bonneville
The Following 10 Users Say Thank You to aerohead For This Useful Post:
10-18-2014, 06:05 PM
Not bad for a machine
Thank you for posting this! Just the inspiration I need to make my own, perfect timing!
10-19-2014, 12:06 PM
I'm thinking I might drop by a gym and see if they have any worn-out threadmill belts, in my head that seemed like the perfect material to make the lower part of an air dam, and not have it break off on a speedbump or ramp..
Similar to the yellow Corvette (?) above..
10-19-2014, 05:45 PM
Spaced out...
That Beetle is awesome
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
10-20-2014, 01:29 AM
Which Beetle?
The guys that were runing the red one said that they have to remove the air dam to get it onto their trailer—and that took 45 minutes each way. Those are 1 1/2" fender washers under Allen-head bolts, and it had Heim rod ends on the struts. Definitely not a coroplast and duct tape effort.
Here's a couple more:
10-20-2014, 08:20 AM
Interesting, there are a few splitters in evidence there too - mainly on the beetles of course, which probably need the downforce. It would be interesting to know why people did what they did with them, though...
10-20-2014, 09:21 AM
Interesting.
Some of these look a lot like my original air dam on my F350.
Mine worked best when I had 3 inches clearance to grade, but it ground everytime I hit the brakes. Not big deal for Bonneville guys.
After aerohead's misadventures with road debris a guy with an aluminum or rigid plastic air dam might want to pre-run the course to FOD it.
BTW, conveyor belt is indestructible but a bear to fabricate.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
10-20-2014, 02:26 PM
Thanks for the pics. I always like seeing how other people build things.
Bonneville is awesome! Where else can you find a modern Japanese import with a 60 year old supercharged flathead!
10-20-2014, 02:47 PM
#9 (permalink)
I'd like to see that. Any links/pics?
I think the ultimate flathead Ford would be the french military flathead - Google Search. It's basically a 49-53 block with an early bellhousing.
10-20-2014, 04:13 PM
#10 (permalink)
Indestructible: Impossible to break or destroy
Inconstructible: Impossible to make or construct!
