Old 06-24-2019, 07:26 AM   #1 (permalink)
Free wheel front sprocket for motorcycle?
Does there exist a free wheel front sprocket for motorcycle?
15 tooth for an NBC110 Honda Super Cub to eliminate engine breaking would be good.
I figure such a sprocket would be an easy install.
I've read about the sprag clutch discussions previously on this forum.
Something like this:
https://www.ebay.com.au/itm/Veteran-...frcectupt=true
Old 06-24-2019, 10:24 AM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
You can buy freewheel bearings, but I don't think they'd handle the torque at the wheel nor at the engine sprocket. Maybe the largest would. (Yes, not very helpful)
Old 06-24-2019, 11:36 AM   #3 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Clutch is how you freewheel.
Old 06-24-2019, 12:25 PM   #4 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Yes...but it would be awesome to be able to freewheel the chain too. Except that would require a freewheeling rear sprocket.
Some motorized bicycle kits come with a freewheeling front sprocket, general consensus is that they are trash, even those 2 hp engines destroy those sprockets. You have to weld them together.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 06-24-2019, 07:30 PM   #5 (permalink)
In that case I'd have to install a clutch on an NBC110 which has a centrifugal clutch.
Old 06-25-2019, 08:51 PM   #6 (permalink)
Break through!
Break through!
The gear lever doubles as a clutch lever, when you hold up or push down the gear lever it engages a clutch in order to change gear and as long as you hold the gear up or down it will free wheel!
I just realized this today on the bike.
I would still like to eliminate engine breaking automatically.
Old 06-28-2019, 02:18 PM   #7 (permalink)
Daschicken's Avatar
Motorcycle
Motorcycle
Motorcycle
Originally Posted by Spaghetti Man View Post
Break through!
I found that out at one point with a Yamaha TTR 90, you can also use it to launch.
The Following User Says Thank You to Daschicken For This Useful Post:
roosterk0031 (06-28-2019)
Old 07-01-2019, 02:52 PM   #8 (permalink)
I gave this some thought while building my C90, took my inspiration from Matt Guzzetta's Suzuki streamliner, he used a starter motor clutch in the rear wheel, far beyond my engineering capabilities.
I never considered a freewheel front sprocket, a much easier project I think.
He did say that the brakes had to be used 'with some authority' because of the lack of engine braking.
A great idea, but I don't think a 'burn and coast' would work so well on such a lightweight motorcycle, it might be useful in a mountainous region.
Using a bigger front sprocket and smaller rear would help. You can certainly go to 16/36 without any issues, pitbike front sprockets will fit and are very cheap so you can experiment.
Pete.
Old 07-22-2019, 10:30 AM   #9 (permalink)
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
A freewheel rear sprocket is definitely the most effective way to reduce drag. Takes the chain out of the equation too. I think I might try the starter clutch idea for my CBR
Old 07-22-2019, 03:38 PM   #10 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
How much hp and torque does an a/c clutch hold up to? Maybe you could go electro-magnetic clutch on the rear wheel to retain engine braking?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
