Old 03-03-2016, 03:49 PM   #41 (permalink)
Originally Posted by samwichse View Post
Pretty much this. Go buy an Insight with a blown engine/crapped out CVT and a dead hybrid battery. Stick your electric bits in. Go.
But you can do it with so much more style by getting a RX-7 FD and they blow engines daily. Also gives more flexibility in transmission.
Cooling system is responsible for 5-10% of vehicle drag. Rule of thumb, input energy is equally split between wheels, exhaust and coolant. As you will be blanking off a 250bhp cooling system instead of 67bhp it will be near to 10% of total drag while the Honda will be around 5%.
RX-7 FD (base) 90% of 0.518 = 0.466 m².
Honda Insight 95% of 0.474 = 0.45 m².
Not cashed in rear wheel spats or disc wheels.
Is it worth it when you will be seen in a Honda Insight?
Originally Posted by renault_megane_dci View Post
I'm interested in that question too but more thinking along the lines of :
Would it be plain stupid to add a perfectly shaped roof addition in order to get a better angle at the back ?
Thanks in advance.
A slant back is nearly as bad as a notch back. All modern hatchbacks although fully conforming to the definition of a Kamm tail have a spoiler that extends the roof line a long way past the hatch to make a recessed transom that is required for a Camm tail.
Old 03-04-2016, 12:50 PM   #42 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
Yes, because I want to be seen in a Honda Insight.
Also: The Insight is all aluminum/plastic. Rust isn't much of an issue with these cars (aside from some fittings). Can you say that about an RX-7?
The Following User Says Thank You to samwichse For This Useful Post:
Fat Charlie (03-04-2016)
Old 03-04-2016, 04:28 PM   #43 (permalink)
I'd like to be seen in an Insight too. I don't drive enough to make updating my fleet worth it though.
I know that I feel like a douche when riding in SUVs.
Old 03-05-2016, 09:44 AM   #44 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
I need to draw a sketch ...
The Following User Says Thank You to renault_megane_dci For This Useful Post:
aerohead (03-05-2016)
Old 03-05-2016, 01:03 PM   #45 (permalink)
spoiler
Ideally,the spoiler would also incorporate the sides such that the aft-body is literally chopped off like a loaf of bread
gumby79 (03-05-2016), NeilBlanchard (03-07-2016)
Old 03-05-2016, 01:55 PM   #46 (permalink)
No, it would not. Replace the square windshield header with a half-circular one and work your way back from there.
AKA bubble-top coupe.
Old 03-05-2016, 03:01 PM   #47 (permalink)
monoposto
There is not much on-line about the Monoposto, in English, at least.
In 1958,Mercedes-Benz used this word to describe any open-wheeled Gran Prix racing car.
Old 03-05-2016, 03:08 PM   #48 (permalink)
back
Originally Posted by jamesqf View Post
Don't know who uses that definition, but it seems a misuse of language at best, since the area would be identical to everything you can see from the back.
Yes,the area of the outline is the same regardless of direction as long as it is longitudinal to the car.It's simply a convention to say 'frontal.' It has nothing to do with the front of anything.
Old 03-05-2016, 03:27 PM   #49 (permalink)
CdA
Originally Posted by duncan View Post
Just a small comment
Frontal area x CD gives drag for a non "streamlined" shape,
There are two types of drag - form drag and skin friction
If you can properly streamline a shape such that the air follows the surface, does not detach and rejoins nicely
Which is nearly impossible in a ground vehicle
Then you eliminate "form drag" and you end up with skin friction which is proportional to the "wetted area" and NOT related to the frontal area
*Frontal projected area (A), X coefficient of aerodynamic drag (Cd), = drag factor (CdA), of any shaped vehicle.
*Surface friction drag + pressure drag = profile drag.
*There's also:
*cooling drag (where applicable)
*ventilation drag (where applicable)
*interference drag
*induced drag
*windage drag associated with the spinning wheels
*When you eliminate pressure drag,your profile drag is reduced to surface friction drag which is associated with the wetted area.
With this graphic for streamline bodies,you can see that pressure drag is eliminated at around l/d= 3.5,then drag goes up as the length increases beyond the l/d 'sweet spot.,' due to the increasing wetted area.
freebeard (03-06-2016)
Old 03-05-2016, 04:02 PM   #50 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Turtle Re: CdA
What is the magic finess ratio in "Ground effect" ??? Because that is were I drive.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
