Old 09-07-2009, 01:29 PM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Fuel Heaters???
Has anyone on here built a fuel heater? This is going to be my next mod.
The temperature in the last few days has drop off into the low 60's F.
I have been doing some testing and have noticed that my FE has drop off a ton due to the cold temps.
I'm running in open loop all the time so my IAT, ECT sensors have adjustable tables and I have made changes to get back to my desired A/F ratio around 19:1 but the engine is surging at this ratio where it did'nt when the temps were in the 80's F.
My thoughts are its a "atomization fuel" problem?
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-07-2009, 02:02 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Fuel saving gadgets - a professional engineer's view
The cold is more of an issue for keeping the engine warm, not the fuel. Since the engine heats itself with combustion energy, you need to consumer extra gasoline to fight with the cold of the air. Hence things like grill blocks were invented
Old 09-07-2009, 02:14 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
The prius has a neat trick for retaining heat, when you shut down it pumps some hot coolant into a thermos, and puts it back in the system wheat next start up. Not %100 of engine heat is retained between runnings of course, but better than nothing.
Old 09-07-2009, 02:20 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
And it should be noted that you can buy said thermos and solenoid and run it off an arduino etc on pretty much any car
Old 09-07-2009, 02:43 PM   #5 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
That's a cool prius trick.
Old 09-07-2009, 02:49 PM   #6 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
ECT temps were 5*F cooler from 197F down to 192F
IAT temps were 38*F cooler from 118F down to 80F
Grill was block off the same as the last two runs. I might have to block it off all the way.
I might have to figure out a way to make my FMIC a FMIH
Old 09-07-2009, 02:49 PM   #7 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Yeah it is, I might have to give that some thought.
Old 09-07-2009, 02:51 PM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
But I should mention that it's easier to just install a block heater
Old 09-07-2009, 02:52 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yah but then techinically it is a hybrid, getting some of its energy from the wall.
Old 09-07-2009, 02:55 PM   #10 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
i dont think its an atomization/vaporization problem, but simple temperature issue. how about a hot air intake? i think a good HAI would provide any help that a fuel heater could, i think it can be done at lower cost, simpler design, and more safely. i always think a grill block is a good idea. i'm not familiar with the coolant thermos, but along that line would also be a block heater... doubt its worth it at 60deg. but in colder climates it would have a greater impact as it gets colder
The Following User Says Thank You to 2000mc For This Useful Post:
pgfpro (09-07-2009)
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
