To change that Metro to an XFi, you need the trans of course, but as far as the engine goes, you really only need to do a cam swap. The XFi pistons only had 2 rings compared to 3 on a non-XFi, but why bother with all that? Changing the PCM with an XFi PCM might help, but not needed.
GeoMetroforum.com - got mpg?
