Old 01-23-2010, 11:28 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
GM Volt 1.4 ICE Range Extender
Hello -
dcb's series-hybrid thread led me to find this :
GM Explains Why the 1.4 L ICE Range Extender was Chosen For the Volt - July 26th, 2008
... why GM went with the 1.4 L non-turbo 4 cylinder engine and found out some other interesting things.
For one thing, per Nitz, "the 1.4L NA four has better brake-specific fuel consumption than the 1.0L turbo when used in steady state mode, as it will be in the Volt application."
Also Nitz claims the four cylinder engine will provide for a smoother transition from EV to range extension saying "the objective is to keep the engine off and when the engine comes on, you don’t want to know it’s on. You want it really smooth and four cylinder is smoother than a three."
Nitz also noted that the four cylinder has a lower cost and that when the turbocharging architecture is added to the 3-cylinder engine, the non-turbo four cylinder engine setup is actually lighter.
CarloSW2
American Solar Energy Society
Old 01-24-2010, 10:41 AM   #2 (permalink)
The Leaf - '17 Nissan Leaf SL
Outback - '16 Subaru Outback
Vaquero - '20 Kawasaki Vulcan 1700 Vaquero ABS
Ok, but why not use a diesel?
Old 01-24-2010, 11:12 AM   #3 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Speculation, I suspect NO{x} emissions and weight. A simple, three-way, catalytic converter can handle gasoline emissions. Also, the lower stresses of the gas engine should give a higher power to weight ratio compared to an equivalent power diesel engine. For example, chain saws seldom use diesel cycles, with one exception, "Comet" from the 1950s.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 01-25-2010, 11:51 AM   #4 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Because they want it to work and they wanted to make it themselves.
Don
Old 01-25-2010, 12:06 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I do have issue with disguising the ICE operation. I think it should be a LOT more obvious that you are going to start burning fuel, or are burning fuel. Perhaps a personal preference, perhaps pandering to soft consumers, but If I bought something as presumptuously named as "volt" and discovered I had been running tons of fuel through it then I would be a little pissed, as someone who is trying to reduce petrol dependencies.
I have to wonder what the range extender is doing to cost/red tape/epa concerns/delays to market. And I have to wonder if GM wants to delay its release.
Old 01-25-2010, 12:51 PM   #6 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Cool
No kidding, a turbo on a range extender was a really dumb idea. They should have just use the 1.0liter then it would have been cheaper, lighter, and more efficient. But they decided to use the Volt as a Range Extender instead of a battery charger so once the battery hits it's Depth of Discharge boom it's ICE powered till you plug in the battery. Thankfully the inefficiency of going through the generator and the drive motor is at least respectable or it'd get worse efficiency than an ICE powered Volt.
There is other variables too. The durability of a 1.0liter Turbo could be less than the 1.4liter if it was ran with the turbo running even half of the time. Turboes are not a good choice on Electric Vehicles anyway.
Why use a diesel?
It's heavier and more expensive. That alone disqualified it before we had a chance to even consider. I'd love to discuss it more. Now with DI getting more expensive I don't doubt the price is becoming comparable to Diesels. But Diesel is necessary for Commercial vehicles so any more competition with business is bad in my book.
And I agree with you dcb. But when they build a mass market car that annoying ICE needs to be silent for them consumers. I don't mind a noisy car even if it is a bit annoying but the silent ones are the dangerous ones. The Prius received flak for being quiet at <35mph but many cars could run you over before you heard them coming at much faster speeds. Double standards. I grew up being extremely cautious about roads and when I did start spending a lot of time around traffic I would still be caught off guard by vehicles that I couldn't see or hear until they were too close for comfort.
-Allch Chcar
Old 01-25-2010, 01:15 PM   #7 (permalink)
Engineering first
This is a side issue:
Originally Posted by Allch Chcar View Post
. . . I don't mind a noisy car even if it is a bit annoying but the silent ones are the dangerous ones. The Prius received flak for being quiet at <35mph but many cars could run you over before you heard them coming at much faster speeds. Double standards. . . .
It turns out noisy SUVs and pickup trucks are the primary pedestrian killers. As for the Prius, the actual fatality rate is much less than the USA fleet:
Prius Fatalities 2001-2007
I would point out GM has not put noise makers on their existing hybrids ...
Bob Wilson
Old 01-25-2010, 01:26 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
I knew that discussion would ring a bell with you Bob
Old 01-25-2010, 01:36 PM   #9 (permalink)
...beats walking...
Bob Wilson
...does that mean EV's are like the prodigal kids, who should be "...seen, but not heard"?
Old 01-25-2010, 05:34 PM   #10 (permalink)
Engineering first
Tuesday morning, C-SPAN, Washington Journal, enjoy:
* Jim Campbell, General Motors Company, Chevrolet General Manager
* Susan Cischke, Ford Motor Company, Group Vice President
* Jim O'Donnell, BMW of North America, Chairman & CEO
Bob Wilson
"The Volt" May BE SCRAPPED!- NEVER BUILT!! Jammer Hybrids 460 08-22-2013 07:08 PM
GM to offer 100% battery powered Volt (no engine/generator) MetroMPG Fossil Fuel Free 7 01-14-2010 08:31 PM
News: GM planning dedicated high efficiency hybrid (in addition to the Volt) MetroMPG Hybrids 17 07-16-2009 10:20 PM
GM admits the Volt concept car's aerodynamics suck MetroMPG Aerodynamics 16 12-13-2008 01:16 PM
Chevy Volt and GM Get Big Boost From $700B Bailout Vote Today Matt Herring EcoModding Central 15 10-09-2008 04:20 AM
