Old 11-25-2008, 06:28 PM   #11 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by dichotomous View Post
right but the amount of energy to heat up that cat would put more strain on the electrical grid, if you live where its main hydropower or clean energy great, but if you have coal fired electricity, bad
Given the emissions before light off I think it'd be worthwhile even w/ electricity from coal. Most manufacturers put the converter in a well so that the rising heat forms a pocket when the vehicle's parked which helps I guess but otoh the catalyst has to get really hot to start working well so there may not be a whole lot a warmer could help with. If anything the best bet would be one of these off a BMW or similar, although that would technically be illegal under federal and some state laws. It looks like it'd be a bit much for a DIY project.
Old 11-25-2008, 11:35 PM   #12 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
Would a glow plug in front of the converter help? They get red hot in 15 seconds. Only take 9 amps. Heck I'll try it can't no more than blow up the exhaust system.
Old 11-26-2008, 12:47 AM   #13 (permalink)
roflwaffle's Avatar
I don't think it can make enough heat where it matters (the honeycomb material w/ the catalyst on it) to matter before burning up, but if ya had access to a smog machine it'd be a neat experiment. In the second link of my last post it looks like the heater is incorporated into the honeycomb material and looks like it would heat the catalyst itself up not just the incoming air.
Old 11-26-2008, 02:45 AM   #14 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Problem with pre-heating the cat - Engines run slightly richer during warm up as a means to heat the cat quickly. A cold cat can handle the excess fuel without gross pollution.
Pre-warmed cat + cold engine == engine still running rich and cat over heating.
At least I think. I have no proof to back this up, other than what I know about excess fuel entering the catalyst, and causing it to heat up substantially.
Old 11-26-2008, 08:16 AM   #15 (permalink)
Ezcape - '15 Ford Escape Titanium
90 day: 20.22 mpg (US)
New style of Cat "pre-heater" equation would be this> 1 bag of Kingsford charcoal+generous dose of charcoal lighter fluid+1 lit match=WAMMO! hot catalytic conveter.
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 11-26-2008, 10:02 AM   #16 (permalink)
dichotomous's Avatar
CivySi - '03 honda civic SI
90 day: 31.99 mpg (US)
engines run rich to heat themselves up, not the cat. my motorcycle runs richer and in a higher RPM at warmup so the engine gets up to temp faster, there is no cat on that. heck, there is no cat on my car either, but thats actually supposed to have one.
Old 11-26-2008, 10:09 AM   #17 (permalink)
dichotomous, the new bikes have them
Old 11-26-2008, 10:19 AM   #18 (permalink)
many 2007 and newer bike do, but not all, and mine does not, its a 2005 and is pre-O2 sensor
Old 11-26-2008, 11:03 AM   #19 (permalink)
Mine either, 89 harley ultra, new ones all do, we are making the parts for the exhuast for them
Old 11-26-2008, 11:43 AM   #20 (permalink)
My car has what I like to call a "Vortex black hole thingy" in place of the catalytic converter I know it's horrible, but there is a resonator with a double helix baffle inside it (read: DNA series performance mufflers) that quiets the exhaust flow without creating a lot of backpressure... the cat was plugged up, so I replaced it, since early Honda catalytic convertors look like resonators anyway.
I'm currently working on a way to put the OEM heatshield on my aftermarket header, too, so they can't see that at the inspection shop.
Less questions I have to answer about the car, the better.
DC/DC Converter Indicator Light TomEV Fossil Fuel Free 2 10-28-2008 09:47 AM
