Old 12-08-2020, 12:55 PM   #11 (permalink)
Hey so when you say assortment , does it come in a kit or something like that? I am bit confused.
Old 12-08-2020, 01:12 PM   #12 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
For anyone in the future reading this thread...just buy a dang inverter welder. Even if you rig it up somehow to your current welding equipment. They're cheap. Probably cheaper than adding your own MASSIVE capacitors and inductors. (The higher the switching/alternating frequency, the smaller of an inductor you can use. 60hz -sssslllllloooooowwww - at 100s of amps, you need a really big inductor. Inverter welders switch at high frequency.)
I second Chipresitor's view that you shouldn't be messing with a power supply if you don't know the basic components...but testing if the bridge rectifier is working is pretty simple...power it up, see if you've got the proper output on the rectifier.
Of course, that means having the dang thing open and live. Not recommended if you don't know what you're doing.
I have GFCI's on my shop's plugs, just in case I'm doing something stupid like that.
Old 01-15-2021, 11:31 AM   #13 (permalink)
Ok I will admit ignorance here, but how does a GFCI protect you from the secondary output of a transformer that isn't grounded?
Old 01-15-2021, 12:03 PM   #14 (permalink)
Stubby79's Avatar
1. If it's on the other side of the transformer, you would have to touch both legs to get zapped. (So, you're sorta right. GFCI won't help in that situation, though you're considerably less likely to zap yourself in the first place.)
2. If it's gone through a transformer, chances are it lowered the voltage and you don't have much to worry about.
3. It's a switch mode power supply(at least that's what I assumed when I wrote that). The rectification happens before going through the transformer.
Mmm...assumptions! Mother of all $%^&-ups!
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-25-2011 12:25 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 08:38 AM
Is this EV AC vs DC for dummies? Or EV lessons from a Power Wheels? ShadeTreeMech Fossil Fuel Free 5 06-21-2010 07:50 PM
AC vs DC for DIY MazdaMatt Fossil Fuel Free 15 03-06-2009 10:33 AM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 10:26 PM
