Old 05-10-2010, 06:09 PM   #1 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Herr Schlör's "Göttinger Ei" had a Cd of 0.186.
http://www.göttingen.de/magazin/arti...p?artikel=3281
Aerodynamik des Automobils ... - Google Books
The oft-cited 0.125 figure seems to be a bit of an EcoModder myth. That figure only applies to a scale model of the Ei.
I believe the .186 figure is consistent with its appearance:
The Following User Says Thank You to RobertSmalls For This Useful Post:
The Toecutter (05-10-2010)
Old 05-10-2010, 07:34 PM   #2 (permalink)
Yes, the 0.13 number was a model or mock up earlier in testing. They also adjusted the ride height to get the optimum drag: too low increased it (due to increased pressure underneath?) and too tall also increased it (probably because more tire was exposed?). We have gone over this, and gotten a lot of pictures, including in the wind tunnel; here's my collection of Schlörwagen "Pillbug" pictures including the Mercedes 170H chassis it was built on:
The 0.18 number is for the actual working car, with cooling set up, etc.
http://translate.google.com/translat...n&hl=&ie=UTF-8
Dr. Charles Schlör died in 1997.
The Following 3 Users Say Thank You to NeilBlanchard For This Useful Post:
BillyBob251 (02-08-2021), tasdrouille (05-10-2010), The Toecutter (05-10-2010)
Old 05-10-2010, 09:06 PM   #3 (permalink)
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
Man, imagine if THAT was the VW Beetle that made cars affordable to Europe... what a different world it would be today.
Old 05-10-2010, 09:06 PM   #4 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Beautiful set of pictures Neil, thanks!
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-11-2010, 12:15 PM   #5 (permalink)
Google Translate
Got any pics of the underside of this vehicle?
It does not appear to have wheel fairings or spats, which would help.
And, gap between vehicle and ground relates to interference drag. There is an optimum height, as noted in Hoerner's Fluid Dynamic Drag book with cites of external stores of bombs, fuel tanks, etc. in aircraft. Too close means a bit of savings from less wetted area of pylon, but more than offset by too much interference of flows around wing and bomb. Too far apart means less interference drag, but increased pylon drag. So, there is a sweet spot in gap adjustment. I think Citroen with its adjustable height also dealt with this issue.
Old 05-11-2010, 02:45 PM   #6 (permalink)
No, there are no pictures of the underside -- all the pictures I know of are here:
Schlor Pillbug pictures by NeilBlanchard - Photobucket
Yes, wheel strakes would help a lot. From the wind tunnel tuft test picture you can see the main problem area: from just ahead of the rear wheels and behind them, the air is swirling up. The tail may need to be broadened and flattened, to improve things?
The other main issue with the Schlörwagen is the width: it is 2.1m (6'-11")which is very wide, indeed. They made it wide so that the front wheels could be fully enclosed, even when they are turned fully. I think that some system of articulated/moving enclosures would keep the advantage, while greatly improving the CdA.
Old 05-11-2010, 05:54 PM   #7 (permalink)
pill
Yes,didn't Hucho say that while he was at VW,that they threw a full-scale version in the tunnel and come up with this value?
Old 05-11-2010, 08:08 PM   #8 (permalink)
I think VW tested a scale model, and they got 0.15, if I am not mistaken.
Old 05-18-2010, 09:57 PM   #9 (permalink)
JackMcCornack's Avatar
Plus so they could claim the lowest Cd of any passenger car of the era. Let us not forget, the easiest way to improve a vehicle's Cd is to make it bigger. "the .186 figure" for a 6'11" wide car would translate to a .257 figure for a 5' wide car with the same total drag. I suspect (cynic that I am) that modern car companies tout their low Cds (or is that "low Cs of d"?) because it looks better than quoting the CdA when promoting a big car. For example, the Cadillac Escalade boasts a "segment-best aerodynamic drag coefficient of 0.36 " which looks pretty cool compared with (for another example) a Mazda Miata at Cd 0.38
Modding MAX, a Kubota-powered classic sports car
http://www.kineticvehicles.com
The Following 2 Users Say Thank You to JackMcCornack For This Useful Post:
RobertSmalls (05-18-2010), tasdrouille (05-19-2010)
Old 05-18-2010, 10:58 PM   #10 (permalink)
Left Lane Ecodriver
Agreed, but let's give credit where it's due. If the Göttinger Ei was 7' wide and 5' tall, it had a CdA of 5.53ft². That puts it on par with the CRX, which only seats two.
The VW Beetle had a CdA of 9.3-9.5ft².
The_Jed (01-24-2015)
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
