Old 06-16-2014, 02:48 PM   #1 (permalink)
White lightning - '98 Nissan Frontier XE
90 day: 22.01 mpg (US)
Higher gears in rear axle to increase gas mileage
Hello, this is my first post as I just registered today, I was curious to know what kind of mileage increase I could expect if I were to install a 3.54 rear axle in my 1998 Nissan frontier in place of the 4.33 axle I have now, my engine is a stock 2.4 Dohc with a four speed auto, my truck is 2wd and I am running 235 75r15 tires in place of the factory 215 65r15.
The Following User Says Thank You to 98frontier For This Useful Post:
101Volts (06-17-2014)
Old 06-16-2014, 02:50 PM   #2 (permalink)
Also, if this is posted in the wrong place please redirect me to the proper location.
Old 06-16-2014, 03:15 PM   #3 (permalink)
What does the tach read at 60 MPH? It it's around 2k RPM, you might not see much improvement.
regards
Mech
Old 06-16-2014, 03:47 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
regards
Mech
wouldnt it depend more on what kind of driving you do?
going from 3.54 to 4.33 should help in the city
while 3.54 to say 2.73 would hurt city help highway
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
Old 06-16-2014, 04:55 PM   #5 (permalink)
Welcome to the site!
I've never heard of taller gearing hurting city mileage. Care to explain Gealii?
I'd recommend taking a look at our wiki page:
Car MPG Efficiency Modifications Main - EcoModder
There are several here who have done regearing stuff. The gains seem to be from 7% to 20%. I'm sure its application specific, but those are pretty huge gains.
The Following User Says Thank You to Daox For This Useful Post:
Old 06-16-2014, 04:57 PM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
It kinda depends on how much city/hgwy driving you do.
The more hwy the better the result.
you can look at my posts w/ Q45 and taller tires. I did 30-40k a yr so a lower rpm at 60mph was a home run for me.
First: what is rpm at 50, 55, 60 on frwy?
Second: how much (%) hwy driving do you do?
since its a truck, its probably geared to 'pull', so going to the 3.xx gear would probable work.
my 66 mustang w a straight 6 200ci had a 2.76 rear.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Old 06-16-2014, 05:00 PM   #7 (permalink)
mcrews's Avatar
oh by the way WELCOME!!!!
increase the psi in your tires to 40+
ECO MODS PERFORMED:
First: ScangaugeII
Old 06-16-2014, 05:07 PM   #8 (permalink)
gears/mpg
*You need to know where you are,with respect to road load horsepower and the engines Brake Specific Fuel Consumption (BSFC)profile.
*For every engine rpm and combined aero,plus rolling resistance load,you'd see a particular rate of pounds of fuel per brake horsepower hour,after factoring in the driveline efficiency.
*This is best done on a chassis dynomometer,where all the loads can be simulated.
*With all the data,you'd construct an engine 'map' which showed a number of islands of constant BSFC,with one in particular yielding the best mpg.
*This would be the best your engine can do.
*And it may be that Nissan has already optimized the gearing for your automatic 4-spd,and changing the ratio arbitrarily might actually lower your performance.
*Until you figure out a way to get a map,you're shooting in the dark.
Old 06-16-2014, 05:09 PM   #9 (permalink)
Well my truck has no factory tach but I did have an aftermarket tach in it a while back, I think with factory size tires it was around 2300, with my new 235 75r15 tires it should be around 2100, and also my tires have a max of 35 on the sidewall, so I run them about 34 or so.
Old 06-16-2014, 05:10 PM   #10 (permalink)
Also I drive mostly highway, probably around 70%
