Old 11-04-2014, 05:28 PM   #31 (permalink)
That a boy. 2 group 24s in the rear where the spare tire ought to be will make it take corners like no ones business.
One more reason to stick with lead.
Old 11-05-2014, 12:28 AM   #32 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Thanks for posting this. I'm thinking about doing this in my Camry. I can remove the belt and run belt free! Which I think will get me some decent gains! Is it ok to charge a deep cycle battery using the alternator? Like say going on a trip longer than the battery can last? Also I was thinking about getting a low wattage solar panel to stick in the dash of my car to trickle charge it while the car is parked say at work or home.
99 Camry
Old 11-05-2014, 08:36 AM   #33 (permalink)
Yeah, the deep cycle will be fine being charged by the alternator. If I have a trip too long I'll be using the alternator. As I progress with this thread, I'll be installing a switch to turn the alternator on and off. I haven't determined exactly how I'm doing that quite yet, but that is one of the next steps.
A solar panel has generally been considered a poor way to charge the battery though, they just don't put out enough power to be worth the cost. It is a very cool idea though.
The Following User Says Thank You to Daox For This Useful Post:
sully06 (11-05-2014)
Old 11-05-2014, 10:11 AM   #34 (permalink)
A solar panel has generally been considered a poor way to charge the battery though, they just don't put out enough power to be worth the cost. It is a very cool idea though.[/QUOTE]
Even sitting in sun for 8+ hrs
99 Camry
Old 11-05-2014, 10:21 AM   #35 (permalink)
Yep, even with it sitting in the sun for 8hrs a day. As I mention in my first post a lot, we have to think about worst case scenario. Worst case is a cloudy week. Unless you have a massive battery, its not going to last a week for you, let alone a week in winter when there is nowhere near 8 hours of sun per day. Then, you add in the other little factors like the windows have UV protection and/or tinting which reduce the panel output. And solar panel output isn't optimal unless the panel is tilted perpendicular to the sun (ie sitting on a dash). The little things start adding up, and the size of the panel you need keeps going up, and you still need a charger for that week where there is absolutely no sun.
A few guys have done it, and I agree its a very cool idea. But IMO there are a lot of other mods that are a lot more beneficial and reduce my commuting cost a lot more. Thus its an idea I'd consider, but its way down on my list to the point I'll probably never get to it.
Old 11-05-2014, 12:14 PM   #36 (permalink)
Thanks! I'm excited to do this modification and see how much mpg gain I see.
99 Camry
Old 11-05-2014, 02:27 PM   #37 (permalink)
90 day: 29.78 mpg (US)
A 5 watt panel in direct sunlight for 8hrs will produce 40 watts of energy assuming no charging losses. My car requires a minimum of 163 watts to run, so 8hrs of charging will get me 15 minutes of run time if I run absolutely no accessories.
The Following 3 Users Say Thank You to redpoint5 For This Useful Post:
mikeyjd (04-15-2015), sully06 (11-05-2014), Xist (11-05-2014)
Old 11-05-2014, 02:44 PM   #38 (permalink)
Thanks
If I do run beltless will I still need to unhook the alternator? Will my scangauage still read?
99 Camry
Old 11-05-2014, 03:43 PM   #39 (permalink)
Thanks
Your car will still run if you have a bad alternator until the battery dies, so as long as your battery lasts, your car should run fine.
Old 11-05-2014, 05:43 PM   #40 (permalink)
Thanks
I would still disconnect the wires to the alternator if you run beltless, but I'm unsure how your particular car controls things.
On my car, a small current is supplied to the alternator to activate the field windings. Even if I remove the belt on my alternator, it will still draw some amount of power in an attempt to activate the alternator. My car uses 4 wires to the alternator to control and monitor charging. A large 5th wire is the actual positive output lead that goes to the battery and powers the car.
