10-09-2008, 09:12 PM
How to get instant fuel consumption from Megasquirt
This works for MS1-Extra/MSnS-E, combat proven. Most probably will also work for MS2. No vehicle speed input is required .
Data we must know beforehand:
- 5th gear ratio
- Differential ratio
- Tractive wheel perimeter in centimeters
- Injector flow in cc
For instance in a Miata NA 1.6 the data are:
- 0.814
- 4.300
- 181.4583917 cm
- 205 cc
Then input the data into this formula:
RPM = ((((100*100000)/60)/wheel perimeter)*(5th gear ratio*differential ratio))
For the Miata:
RPM = ((((100*100000)/60)/181.4583917)*(0.814*4.300)) = 3215 (this will be the magic number)
Now open with notepad the msns-extra.ini file, the path is C:\Program files\MegaSquirt\your-project-car-name\msns-extra.ini . Then choose your way ...
OPTION ONE: FOR LITRES/100KM DISPLAY
Look for this paragraph towards the end of the file:
Code:
; CHANGE THESE TO SUIT YOUR CAR TO GET MPG, MPH, ETC. THIS WILL ONLY WORK WITH A SUITABLE
; VEHICLE SPEED SENSOR CONNECTED TO MSnS-EXTRA CODE.
Speed = { 70 } ; Change this to your actual speed @ 2.5V from VSS circuit
fuelCC = { 2168 } ; Enter the total flow for all your injectors here in cc/Min
squirtmul = { divider1 < 2 ? 2 : divider1 < 3 ? 1 : divider1 < 5 ? 0.5 : divider1 < 9 ? 0.25 : divider1 < 17 ? 0.125 : 1 }
squirts = { alternate1 > 0 ? rpm100 / 0.6 * squirtmul : rpm100 * 2 * squirtmul / 0.6 } ; How many squirts per Sec
OpenWidth = { injOpen1 * 0.1 } ; Pulse width for injector opening time
CCpHr = { pulseWidth < 1 ? 1 : (fuelCC/60) * ((pulseWidth - OpenWidth)/1000) * squirts * 3600 } ; cc / hr
mphTemp = { fuelADC < 1 ? 0 : (fuelADC * Speed) /127.5 } ; MPH
mph = { mphTemp < 1 ? 0 : mphTemp } ; Ensure we get 0 mph
USgph = { CCpHr / 3785 } ; US Gallons / Hr
USmpg = { fuelADC < 1 ? 0 : mph < 1 ? 0 : mph / USgph } ; US Miles / Gallon
gph = { CCpHr / 4546 } ; Real Gallons / Hr
mpg = { fuelADC < 1 ? 0 : mph < 1 ? 0 : mph / gph } ; Real Miles / Gallon
In 'fuelCC' we must enter the injector flow, times number of injectors (if simultaneous injection). Or injector flow, times number of injectors, divided by 2 (if batch injection). For this particular Miata it is (205*4)/2 = 410 :
Code:
fuelCC = { 410 } ; Enter the total flow for all your injectors here in cc/Min
Now we add an user defined variable with its formula:
Code:
L100in5th = { (CCpHr/1000)*(3215/RpmHiRes) } ; Litres/100 in 5th gear
Now we look for the paragraph ' [GaugeConfigurations] ' :
Code:
; Extra Stuff
mpgGauge = mpg, "MPG", "MPG", 0, 100, -1, -1, 100, 100, 1
YGForceGauge = YForce, "Y G-Force", "G", -3, 3, 0, 0, 2, 3, 3
XGForceGauge = XForce, "X G-Force", "G", -3, 3, 0, 0, 2, 3, 3
MAFGauge = MAFVolts, "Volts", "V", 0, 5, 0, 0, 5, 5, 2
bcDCGauge = bcDC, "Boost Control DC", "%", 0, 100, -1, -1 999, 999, 0, 0
idleDCGauge = idleDC, "Idle DC", "%", 0, 100, -1, -1 999, 999, 0, 0
RealDutyGauge1 = dutyCy1Real, "Fuel Delivery 1", "Flow", 0, 75, -1, -1, 75, 75, 1, 1
RealDutyGauge2 = dutyCy2Real, "Fuel Delivery 2", "Flow", 0, 75, -1, -1, 75, 75, 1, 1
And we add this line at the end of the paragraph:
Code:
; Extra Stuff
L100in5thGauge = L100in5th, "F.Cons. in 5th", "l./100", 0, 30, 0, 0, 10, 20, 1
Lastly we look for the ' [FrontPage] ' paragraph:
Code:
[FrontPage]
#if NARROW_BAND_EGO
egoLEDs = 0.0, 1.0, 0.5 ; NB settings.
#else
; If you reverse these range values as you see below, then the LED
; bar will work as you expect, high on the right, low on the left.
egoLEDs = 4.0, 1.0, 2.5 ; WB settings.
#endif
; Gauges are numbered left to right, top to bottom.
; 1 2 3 4
; 5 6 7 8
;Gauge Setup 0
gauge1 = RpmHiResGauge
gauge2 = cltGauge
gauge3 = pulseWidth1Gauge
gauge4 = dutyCycle1Gauge
gauge5 = mapGauge
gauge6 = matGauge
gauge7 = afrGauge
gauge8 = advanceGauge
And do this change:
Code:
[FrontPage]
#if NARROW_BAND_EGO
#else
#endif
; 1 2 3 4
; 5 6 7 8
;Gauge Setup 0
gauge2 = cltGauge
; gauge4 = dutyCycle1Gauge
gauge4 = L100in5thGauge
gauge5 = mapGauge
gauge6 = matGauge
gauge7 = afrGauge
Job done. Save the msns-extra.ini file. Next time you open Megatune you'll see a new virtual gauge showing instant fuel consumption in litres/100 km, something like this (increase brightness if necessary):
It will only be valid for the 5th gear, but it's precise and free.
OPTION TWO: FOR USMPG DISPLAY
Code:
In 'fuelCC' we must enter the injector flow, times number of injectors (if simultaneous injection). Or injector flow, times number of injectors, divided by 2 (if batch injection). For this Miata it is (205*4)/2 = 410 :
Code:
Code:
USMPG5th = { 235.2/((CCpHr/1000)*(3215/RpmHiRes)) } ; USMPG in 5th gear
Code:
; Extra Stuff
Code:
; Extra Stuff
USMPG5thGauge = USMPG5th, "USMPG in 5th", "USMPG", 0, 30, 0, 0, 10, 20, 1
Code:
[FrontPage]
#if NARROW_BAND_EGO
#else
#endif
; 1 2 3 4
; 5 6 7 8
;Gauge Setup 0
gauge2 = cltGauge
gauge5 = mapGauge
gauge6 = matGauge
gauge7 = afrGauge
And do this change:
Code:
[FrontPage]
#if NARROW_BAND_EGO
#else
#endif
; 1 2 3 4
; 5 6 7 8
;Gauge Setup 0
gauge2 = cltGauge
gauge4 = USMPG5thGauge
gauge5 = mapGauge
gauge6 = matGauge
gauge7 = afrGauge
Jod done. Save the msns-extra.ini file. Next time you open Megatune you'll see a new virtual gauge showing instant fuel consumption in USMPG, something like this (increase brightness if necessary):
10-09-2008, 10:56 PM
Dartmouth 2010
Wow, this is neat stuff. I wonder if there's anyway to program it to detect the other gearing so that you could use it all the time, but I think that would require speed sensor input to compare against the rpms...
Thanks for all the great info!
10-10-2008, 06:56 AM
By defect, Megasquirt lacks VSS and is physically unable to detect which gear is engaged, so the only way would be a virtual gauge for each gear (five or six total). As above but doing calculations and adding code for every gear.
The result would be something like this:
You'd have to watch the gauge corresponding with the gear engaged at every moment. V.g. when in 3rd gear only the 'USMPG in 3rd gear' gauge would be true, the other four would lie.
10-29-2008, 01:58 AM
How, convenient, I have a 1.6 Miata  . Thanks for the info!
03-03-2009, 06:33 PM
this is so awesome i had to register to say this!
And also ask a question
I dont know my gear or diff ratios, but i can find out exactly what RPM i am doing at certain GPS speed, can i use this information and plug it into the formula?
If the formula is establishing distance covered for every engine revolution in 5th then surely it can be done?
Thanks guys
04-28-2009, 02:24 PM
Manic Rabbit
bumping this for myself.... gotta set this up on my laptop when I get home
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
04-28-2009, 03:35 PM
btw, it doesn't work on MS2 extra because it doesn't have the variables set up for it in the ini like MS1 extra does (for some reason). I got it working on MS2 extra after some ini modding  .
small write-up here
04-28-2009, 03:37 PM
needs more cowbell
It *might* be worth it to add a speed signal to the cpu. I know I cover a lot of ground with the engine stopped.
05-27-2009, 03:51 PM
#9 (permalink)
small write-up here
Nice work djivesp! Could you please email your MS2 ini file or something it can copy and paste to matasjeff@yahoo.com so that I can try it?
Also, is there a variable for changing fuel pressure used for vehicles with 1:1 vac/boost fuel pressure regulators?
Thanks,
Jeff
05-27-2009, 07:28 PM
#10 (permalink)
I put ms2 on a little thinkpad and created a RJ-45 female to DB9 female to extend my one stock SGII OBII cable to the serial port on my thinkpad. This failed, but I wonder if it is because I have a honda - I did a quick google search and found that some honda people either achieved no success with MS2, or had to do a lot of little tweaks to get it to work. Does anyone know about this or have any tips on where to proceed next? I'm pretty sure my cable is fine.
