Old 08-24-2011, 02:09 AM   #1 (permalink)
Enki's Avatar
Time for some overkill.
Because I will eventually run my car at the ragged edge, I aim to make damn sure I know what's going on with it.
So, with a couple of goals in mind, I did some research and wound up buying a Nook Color, and dropping a custom ROM (OS) on it. Combined with the Torque app, I have some pretty decent monitoring going on.
First, the PLX Kiwi Bluetooth:
Next, how it's wired/routed:
Sunny Nook:
Shaded Nook:
RAM mount:
Torque UI:
So, it works, but I'm running into issues with the speed of updating which is looking to be a problem with the adapter (as I've tested everything else). I guess all that remains is to get on the horn with PLX and find out some info about this device, as I really need the high speed resolution in logging.
Old 08-24-2011, 10:25 AM   #2 (permalink)
...beats walking...
...interesting, so you're "blue-tooth" transmitting the OBD-II signals up to a Nook Color and using what software display package?
Old 08-24-2011, 10:50 AM   #3 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
That's a good size for a Torque display. Very nice job.
Transmission type Efficiency
Old 08-24-2011, 12:03 PM   #4 (permalink)
Enki's Avatar
The Android app is called Torque. There is a free version, but I'm rolling with the paid version.
More info on the Nook Color:
Fully rooted and flashed
Running CyanogenMod 7 (latest nightly alpha build)
Overclocked from 800 Mhz to 1100 (with room to grow)
16 gig class 10 SD card
And yes, I can still read books on it.
Like I said before, there is a problem with my setup; the data rates aren't exactly stellar. According to PLX's support forums, their dongle runs at full bluetooth 2.0 speed, so that shouldn't be the issue; I'll be doing one more test this afternoon to figure out if it's the bluetooth radio on the Nook or something else.
It's decent, but not yet perfect.
Old 08-25-2011, 07:34 PM   #5 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
I got a nook color and want to root it bad but have not found a good step by step on how to do it. I dont care to OC though.
Old 08-25-2011, 08:36 PM   #6 (permalink)
Enki's Avatar
It is a little tricky, but basically you need a MicroSDHC reader (or a cell phone will do) and a few files to put on it. Essentially, the Nook will boot from the SDHC card natively, so you don't technically have to root it I don't think.
XDADevelopers has a whole section on the Nook color; you should start there and read up.
Old 08-25-2011, 08:53 PM   #7 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
I am using a "cheap ebay" ELM327 unit.
No data stream issues.
Torque is running on a Tmobile MyTouch Slide.
I hope its not the nooks bluetooth transmitter as I hope to do the same when I have a few loose $$
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 08-25-2011, 09:09 PM   #8 (permalink)
Enki's Avatar
I did a mountain of testing; long story short, it isn't the Bluetooth kit in the Nook Color. If anything, the hardware it has is actually overkill on a fairly significant degree for what Torque needs.
Ian (the Torque developer) has some improvements in store for CANBus interaction which should significantly improve polling/logging rates, so time will tell.
For those of you that care, on the latest nightly I was able to transfer a file from Windows to the Nook via Bluetooth at just over 100 KBps; My HTC Evo running the same nightly (different kernel, obviously) clocked only a few KB faster.
Basically, I'll just let Torque auto-update and one day it will grow a mohawk and start headbanging data out.
Old 08-25-2011, 10:13 PM   #9 (permalink)
Rat Racer
Ian does a good job. It's a great app.
