Old 09-29-2015, 05:48 PM   #11 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
There is 10ft of travel in the landing gear? The payload is perched over a trap door????
It'd hang from the top structure, with the sides making sure the beam doesn't flex.
The top and sides of the airframe will have to be stiffened to allow that size a hole in the fuselage. One would think.
Try bending a U-beam
That's essentially what this design is, with added aerodynamic covers.
Bottom would merely be an aerodynamic cover.
I posit a better strategy: one 8x8.5 hatch in the side and rollers in the floor so it can be loaded like an 18-round magazine.
Which would make it heavier as you'd need a floor to support the weight, the rollers, the hatch in what would be a truss-structure to keep the aircraft from bending.
The aircraft would need equipment to roll loaded 40' containers - that'd require some heavy duty powered rollers.
Every airport would need lifting equipment that can lift 40' containers.
CoG issues could pop up when loading the containers as you'd have to load those at the extreme ends first.
The side cargo door in the C-130 was deleted @ a very early stage.
In later cargo/tanker jets, this door is above the load-bearing structure (floor and beam) and requires specialised loading equipment
Also, airplanes are sensitive to weight distribution. The containers are a standard shape, but the weight could vary. They would have to be ordered correctly.
Exactly what's being done on ships and aircraft alike, today ...
So... Your airframe seems to be sized for 40ft containers. Can it accommodate two 20ft containers? Another aircraft half the width for those?
It's mentioned in the patent
If the rear aerodynamic tail was made to fold up - or deleted altogether and accepting higher drag- it could mean the cargo can be rolled under the aircraft from behind, rather than the aircraft lifting itself over the containers
That should save some complexity with the landing gear.
OTOH, the extendable landing gear would also allow for some seriously outsized cargo to be carried , possibly with some fairings
It'd dwarf the Beluga or Dreamlifter.
The Following User Says Thank You to euromodder For This Useful Post:
Lowell.B.Campbell (09-29-2015)
Old 09-29-2015, 11:29 PM   #12 (permalink)
A U-channel fails by flexure of the free edges. A truss would help. In this case the inverted U-shaped fuselage might be engineered to take tension cables. With an inflated mattress in compression to inhibit flutter.
Are the containers secured by their top or bottom corners?
Oh sure, make me read the patent.
Edit: We basically cross-posted. If the containers are locked into a rigid array, that I can see.
The 40x144ft 'tarp', not so much. Maybe an inflated skin that is sucked against the bottoms of the containers?
Does FedEx have runways that will accommodate these?
Lowell.B.Campbell (09-30-2015)
Old 09-30-2015, 09:52 AM   #13 (permalink)
Originally Posted by Lowell.B.Campbell View Post
You should look at another one of my Patents:
US8608109 - Payload use of wing to body volume in an elliptical fuselage - Google Patents
It was styled after the X48C
This would be more of a blended wing, than a lifting body, right?
Patent US8608109 - Payload use of wing to body volume in an elliptical fuselage - Google Patents
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Lowell.B.Campbell (10-15-2015)
Old 09-30-2015, 09:56 AM   #14 (permalink)
Originally Posted by markweatherill View Post
Co-pilot: Hey, what's this red button do?
Pilot: DON'T TOUCH THAT..... Oh no, not again! Bombs away!
Actually, a way of jettisoning the cargo mid-flight in case of emergency or catastrophic weight shift might not be a bad idea.
Just saw five minutes of the film "Operation Dumbo Drop" where the elephant was causing havoc. Probably just stuck in my head still.
Operation Dumbo Drop (1995) - IMDb
Chin Spoiler:
Roof Wing
Old 09-30-2015, 04:40 PM   #15 (permalink)
jettisoning
Remind me to beef up my umbrella.I didn't anticipate cargo containers raining down.
Old 09-30-2015, 10:24 PM   #16 (permalink)
https://en.wikipedia.org/wiki/Nation...nes_Flight_102
What happens when a few elephant sized military vehicles cut loose. The video is on Youtube.
Containerized cargo would be baffled, and therefore safer.
Old 10-26-2015, 09:31 AM   #17 (permalink)
Terrible incident, they would fire/court-marshal the guy/gal responsible for securing the load but I think they remain on board just in case.
Make a mistake and you not only kill yourself, you kill your whole crew.
Chin Spoiler:
Roof Wing
Old 01-12-2016, 10:40 PM   #18 (permalink)
A second patent on same airplane just got picked up by Popular Mechanics:
Boeing Designed a Strange Plane Would Suck Up Shipping Containers
Be sure to watch the video:
http://patentyogi.com/american-inven...er-deliveries/
The Following 2 Users Say Thank You to Lowell.B.Campbell For This Useful Post:
aerohead (01-13-2016), BamZipPow (01-13-2016)
