01-02-2016, 11:01 PM
#61 (permalink)
Furry Furfag
Doax, did you wait 5-10 minutes between coats? Also, if the temp is below 75F, it will not cure properly and will run on the next pass.
01-03-2016, 08:31 AM
#62 (permalink)
The Metro mainly lives outside. It does occasionally get garage time.
Yes, I did wait about 25 minutes between coats and I did it inside so I was within the specified temperatures they say in the instructions. They do say its designed to only need one coat, but you can put two on.
02-12-2016, 01:11 AM
#63 (permalink)
I bought one of those kits for the VW. It has real hazy head light lenses and the Germans never make anything easy to work on so I am not looking forward to finding out how difficult changing the head lights can be.
I figure I can at least use the UV protector on the new head lights I just installed in the Hyundai and the plastic lens LEDs on my suburban.
02-12-2016, 08:31 AM
#64 (permalink)
I just used the kit on my sister's Jetta I'm working on. Her headlights actually have some deterioration inside the housing though... they were pretty horrible, and now they're okayish.
02-12-2016, 09:42 AM
#65 (permalink)
one of thOOOse people
You can open headlights by baking them in the oven at ~ 200*F for 5 minutes and prying them open. Then clean them out, polish if necessary, and use new silicone caulk to re-assemble. I've done it a couple times with good results.
The Following User Says Thank You to hamsterpower For This Useful Post:
02-22-2016, 11:27 PM
#66 (permalink)
Will be doing this mine are bad as well.
02-23-2016, 05:13 AM
#67 (permalink)
I posted Turtle's headlight restoration in December of 2014 in this thread, and the Blue Magic lasted a little over a year. It was starting to haze lately, so my son brought Turtle over and we re-applied Blue Magic restorer and Blue Magic sealer.
I applied it with my cone buffer again, and it literally took only about five minutes to do both headlights. A year in the scorching Florida sun isn't bad for a five minute job!
The Following User Says Thank You to cowmeat For This Useful Post:
04-13-2016, 05:37 AM
#68 (permalink)
WOBD2
What method did you use to polish and seal?
04-13-2016, 08:31 AM
#69 (permalink)
The factory lights in my 04 jetta were looking pretty scabby. I polished them with a (turtle wax product--I think) and less than a year later they were looking pretty scabby again.
Conveniently, or not, I hit a deer and got two new factory headlights, and less than a year later, you can see some kind of surface coating has failed in a patchy pattern. For what they cost, I expected better.
Looks like buffing and sealing are in my future.
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
04-13-2016, 08:32 AM
#70 (permalink)
I use the cone buffer below that attaches to my cordless drill to buff them out.
Then I use the spray on Blue Magic sealer to seal them.
Meguiar's Brilliant Solutions Wheel Polishing Kit - Walmart.com
