Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 01-25-2009, 04:00 PM   #11 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
FYI, there's a pipeline that carried oil from Oklahoma to Chicago for many years. Now, it flows the other way.
I've debated the merits of electric bikes with the best experimenters, but as a long-time cyclist, I'm most concerned with pedal feedback. My friend built an electric motorcycle with a pedal generator, but it was only 50% efficient. On a mechanical bike, I sense the efficiency and acceleration directly, which helps encourage my best effort. An exercycle - like rig is not as inspiring, if it just helps extend a battery range.
A twist-grip control on an electric bike just makes it feel like a woefully underpowered motorcycle. However, the same motor with a pedal-effort sensor makes you feel like bionic man.
So, I really like the idea of making the pedal power integral to an electric power train. However, I think that the same effect and efficiency can be had just using controllers on existing hardware instead of developing a special unit. The force sensor could shift a mechanical transmission for optimum leg efficiency, if you want an automatic transmission, and still let us sense the change of cadence between shifts.
Old 01-25-2009, 06:06 PM   #12 (permalink)
The HSD-like system will replace the existing transmission. My idea is to separate the pedal power from the electric boost/regen. In other words, the bike will just work like a normal bike if the twist handle is in its center position, only regening slightly while pedaling to make up for the small amount of power used to run the electronics. If the twist handle is in accelerate, it will use the battery to add power. If the handle is in regen, it will regen while charging the battery. The "gear shifting knob" is used to change the virtual "gear ratio".
However, since it is coordinated in software, it can also operate in fully automatic mode. With more processing power than a 486 (in the Parallax chip), the possibilities are nearly endless!
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old Yesterday, 05:11 PM   #13 (permalink)
A hybrid bicycle with an electric Continuously Variable Transmission (CVT) offers a versatile and efficient riding experience. The electric CVT allows for seamless, automatic gear shifts, providing smooth transitions between speeds without the need for manual adjustments. This is particularly beneficial for varying terrains, as it optimizes power usage and improves energy efficiency. Paired with an electric motor, the hybrid bike can offer pedal-assist modes, making uphill climbs and long-distance rides more comfortable. Overall, this combination enhances both the convenience and performance of hybrid bicycles, catering to both casual riders and commuters.
Test: 200w electric bicycle efficiency = 1512 MPG equivalent MetroMPG Fossil Fuel Free 30 07-03-2008 12:25 PM
Making an electric bicycle (looking for advice) NoCO2 Alternative Transportation 44 06-04-2008 02:54 PM
Hybrid Electric Scion xB trikkonceptz Hybrids 5 06-02-2008 05:14 PM
Homebrew Hybrid concept. Would it work? bennelson Hybrids 12 04-30-2008 03:30 PM
electric bicycle... johnpr Fossil Fuel Free 0 03-03-2008 12:07 PM
