Old 09-22-2012, 12:27 AM   #21 (permalink)
Camry Crusader - '01 Toyota Camry LE
90 day: 30.76 mpg (US)
A few things I need to adjust or experiment with to see how much of a difference it makes are...
--Driving with load instead of cruise control. This one is iffy because my foot can never seem to keep a constant pressure on the highway...I wonder if it would help IF I used cruise control on the flat sections and DWL on the rolling areas...???
--Accelerating from a stop, keeping the RPMs below 2,000...gradually reaching my top speed or accelerating from a stop to 2,000-3,000 RPMs to reach my top speed more quickly. Which would save more fuel...???
Since I have an automatic transmission, I cannot perform Engine-off coasting...I wouldn't feel safe doing that anyway unless I knew the technique very well. What techniques can I do that are just as efficient???
Old 09-23-2012, 07:50 AM   #22 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Originally Posted by LostSouthernStar View Post
Which gauges of these should I use to hypermile???...
-% Engine Load
-Instantaneous MPG
-Average MPG
-Instantaneous Gallons/Hour
-Trip Average MPG
-Srt Trip Average MPG
-Distance To Empty (DTE)
Put instant and short trip mpg in big blocks on top and the rest in four small blocks on the bottom. I know there are five here- let % load and instant mpg fight over the last slot, whichever proves most useful to you.
Transmission type Efficiency
Old 09-23-2012, 06:45 PM   #23 (permalink)
Thank you. You typed instant MPG twice, did you mean to say something else?
Old 09-24-2012, 08:07 AM   #24 (permalink)
Rat Racer
Sorry, I meant to let % load and instant gph fight over which is more useful to you.
The Following User Says Thank You to Fat Charlie For This Useful Post:
LostSouthernStar (09-26-2012)
Old 09-24-2012, 11:40 AM   #25 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Absolutely. You've got it.
Old 09-26-2012, 03:57 AM   #26 (permalink)
Really? But how would I know exactly when to engage and disengage the cruise control?
Also, wouldn't that be alot of wear and tear on the system?
Old 09-26-2012, 03:59 AM   #27 (permalink)
Also, I'm worried about leaving the UltraGauge plugged in 24/7 for fear of it draining my battery...how do I prevent this???
Old 09-26-2012, 07:46 AM   #28 (permalink)
Rat Racer
It won't.
LostSouthernStar (09-27-2012)
Old 09-26-2012, 10:10 AM   #29 (permalink)
Easy: look for hills! If you're driving where in hills, constant throttle or "DWL" (driving with load) is more efficient. If it's flat, cruise will be just as efficient.
Nope.
