Old 04-25-2011, 07:21 PM   #11 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
The Ultragauge shows instant, trip, and average mpg. You can reset the latter two whenever you want. I reset the trip mpg when I reach my destination and when I return home. I reset the average mpg when I refill my gas tank. So my trip mpg tells me trip mpg, and my average mpg tells me tank mpg.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
JohnnyRun (04-26-2011)
Old 04-26-2011, 12:14 PM   #12 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I don't see as large a difference between Neutral & drive as a few folks posted. I definitely do see a difference though. The Wife's Hot Rod goes from about .6gph to .4gph. The Scangage isn't allowed in her car, so that's using the factory gage. In my Suburban I go from .6 to about .54.
One thing to remember is that the automatic transmission is still pumping fluid around being ready to be used when in drive. This takes energy to do. Putting it into Neutral pumps less fluid requiring less energy. The main throttle plate stays in the same position but the idle air control valve (much smaller butterfly on the side) is being opened to try to maintain rpm.
Don
The Following User Says Thank You to DonR For This Useful Post:
Old 04-26-2011, 12:20 PM   #13 (permalink)
Pishtaco
SentraSE-R's Avatar
There's no reason to run the engine at all when you're stopped at a red light. Turn it off if you anticipate being stopped >7 seconds. 0 gph is a lot better than .2-.4 gph idling.
Darrell
Old 04-26-2011, 03:36 PM   #14 (permalink)
Van - '00 Chevy Astro 2WD Passenger
That makes a lot of sense, but I wouldn't want to overwork the starter motor too much. I'm thinking of going with the Ultragauge then... Does it say GPH like MetroSchultz mentioned in his reply? I'm sorry to be asking so many question, I just want to make an educated purchase! And do you have to set it up once you connect it to the car?
Old 04-26-2011, 10:36 PM   #15 (permalink)
Pishtaco
SentraSE-R's Avatar
Since I started hypermiling 40,000 miles ago, I've saved $1700 compared to getting EPA combined mpg estimates. That's more than enough to buy a cartload of starter motors . I calculated that idling at a 2 minute stoplight can drop a ten mile 30 mpg trip average down to 28.5 mpg.
Yes, the UG can display instantaneous GPH, average GPH - general, and average GPH - trip.
Darrell
Old 04-27-2011, 09:56 AM   #16 (permalink)
Woah, thats an impressive figure :O So you haven't had any problems with your starter over the years?
Old 04-27-2011, 11:24 AM   #17 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
My Odyssey also does better in Neutral at a stop. .45 gph vs .6 in Drive.
A warm-engine start is very gentle on the engine and starter. My civic (manual, so the idle in N vs D is irrelevant) has 185,000 miles on the original starter, ~40,000 of that with serious hypermiling. It's fine.
