01-19-2018, 06:53 PM
#11 (permalink)
Scangauge should be able to show gallons per hour fuel consumption; that would definitely drop with this change.
01-20-2018, 12:39 AM
#12 (permalink)
4,000 lumens each?
01-20-2018, 11:23 AM
#13 (permalink)
Originally Posted by Xist
4,000 lumens each?
Yes, 8,000 lumens for the set.
01-20-2018, 11:28 AM
#14 (permalink)
SI lumens or chinese lumens?
The Following 3 Users Say Thank You to teoman For This Useful Post:
01-20-2018, 11:33 AM
#15 (permalink)
I don't know, but they're BRIGHT.
01-20-2018, 01:52 PM
#16 (permalink)
...beats walking...
Question now is: will they STAY bright for a reasonable length of time before failing?
01-20-2018, 02:50 PM
#17 (permalink)
The standard Sylvania low beam is 910 lumens and the high beam is 1700.
Well, it saves energy while binding oncoming traffic.
Brilliant.
01-20-2018, 03:39 PM
#18 (permalink)
What lights did you convert from?
I'm not familiar with the HB4 element designation. I have H-4s.
Did you convert one light and then take a picture of the beam pattern on high- and low-beam against a wall?
I converted from halogens to LEDs in the Hella H-4 housing. The phenomenal low-beam cutoff went away. I had to apply a field expedient fix:
Also the halogens had good high beams, I could light up reflectors on road signs a quarter mile down the road. The LEDs have good color temperature, but don't have that reach.
For another thread I was looking at beeping backup lights. They only seem to be available in halogen. Backup lights would be a good use case for LEDs.
.Moore’s Law suggests that good things come to those who wait. Wright’s Law says that good things come to those who act.
01-22-2018, 01:50 AM
#19 (permalink)
The phosphor will degrade in a high power application like car headlights where things get quite hot, but it should be good for a few thousand hours before losing 30%-50% of its light output, dependent on specific circumstances like ambient temp, which bulb you buy, etc.. At which point, it would become only as bright as an OEM bulb.
I definitely noticed that the highway mpg would go down by a tiny bit when turning on the OEM lightbulbs, but I imagine the fuel savings won't really pay for the bulb. The more important thing is that you get a brighter bulb that doesn't hog electricity and doesn't burn out quickly and abruptly. JDM Astars have a good beam pattern that let you see out in the distance without blinding traffic and correctly advertised lumens rating, and you can get the same bulb from their OEM for I think 100 bucks on Ebay, that's the one to get.
01-31-2018, 04:42 PM
#20 (permalink)
EcoModding flying lizard
An interesting benefit I noticed when I got my LED low beams is that the headlights do not dim when I restart the car with lights still on. Less draw=easier starting!
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
