09-14-2015, 04:20 PM
#21 (permalink)
If I could avoid a chain, I would. BTW have you never considered shaft-drive like the BMW R-Series motorcycles?
09-14-2015, 04:48 PM
#22 (permalink)
CFECO
Heavy, complicated, and expensive. I've got it down to 4 bearings on each swing arm, two for swing arm to driveshaft and two...driveshaft to frame, the driveshaft being the swing arm pivot. I am also closely looking at the drive chains being on the inside of the swing arms, simpler... but must have very good differential output shaft alignment with the swing arm pivot axis.
09-14-2015, 04:53 PM
#23 (permalink)
Indeed.
Why not just getting a chain cover like the one used in some variations of the Honda Cub design?
09-14-2015, 04:56 PM
#24 (permalink)
CFECO
Here is the current swing arm pivot-driveshaft bearing design.
09-14-2015, 04:58 PM
#25 (permalink)
CFECO
Chain Cover? For what reason? I'm not familiar with the Honda Cub, but will look it up now.
09-14-2015, 05:00 PM
#26 (permalink)
To keep it sealed in a watertight case, avoiding small debris to adhere to the chain grease and accumulate there, improving the chain useful life.
09-14-2015, 05:03 PM
#27 (permalink)
CFECO
Looks to be simply a "Guard" to keep fingers and sticks out of the chain. Motorcross bikes tend to just chew up and spit out either of those that venture into the chain area. I had a friend who actually ran his ring finger through the primary sprocket of a Yamaha 100. Wasn't pretty, then or ever after.
09-14-2015, 05:08 PM
#28 (permalink)
Basically, that's it. Anyway, as one of your goals for the hybrid side-by-side it to keep it silent enough to look at the wildlife from a closer distance, maybe some degree of noise suppression could be listed on the advantages of having a chain cover
09-14-2015, 05:16 PM
#29 (permalink)
CFECO
Here is my current motor choice, somewhat expensive, but Extreme efficiency and power, and only need one of these. The current chief Engineer of these motors is the original inventor of this style Pancake motor. Too bad Briggs and Stratton does not still make these!
09-15-2015, 12:26 PM
#30 (permalink)
Originally Posted by cRiPpLe_rOoStEr
Anyway, as one of your goals for the hybrid side-by-side it to keep it silent enough to look at the wildlife from a closer distance...
Don't know if that's going to be achievable, though, as you'd still be left with tire noise. In my experience, anyway, most wildlife can hear mountain bike tires, horse hooves, and even normal walking.
The Following User Says Thank You to jamesqf For This Useful Post:
