Old 12-22-2011, 10:12 AM   #1 (permalink)
Smash 100 MPG barrier
mbrac's Avatar
Frankie - '07 Ford Focus SEL
idle it too high when coasting...
So I'm driving a 2007 Focus - 2.0 L - and it seems like when I'm coasting - the idle stays around 1500 - and does not go down to 750 until I come to a complete stop. With this condition - it almost defeats the purpose of shifting into neutral when coasting up to a stop. Anyone know what might be causing this? I don't think it's the TPS as the pedal does not get touched from the time I shift into neutral to the time the vehicle comes to a complete stop. Any advice would be appreciated - Thanks!
Old 12-22-2011, 10:29 AM   #2 (permalink)
My 05 Aveo did the same thing along with my 03 Matrix. I think its a "feature" to make the car more drivable for the normal putz.
The Following User Says Thank You to Daox For This Useful Post:
mbrac (12-22-2011)
Old 12-22-2011, 10:32 AM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Clean your Idle Air Control Valve? My '06 Scion xB MT & Hyundai Elantra AT drop quickly to 700-750 rpm in neutral.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
mbrac (12-22-2011)
Old 12-22-2011, 11:22 AM   #4 (permalink)
do you have a check engine light on?
a vacuum leak will cause high idle, but usually you will get a check engine light with it.
Old 12-22-2011, 11:26 AM   #5 (permalink)
mbrac's Avatar
Thanks everyone for your input - I think I'm going to try cleaning the Idle Air Control Valve - since it's only affecting it when coasting - if that dosen't do it - I'll just replace it- cost from Autozone is $54 - no error codes - just noticed it since I became an ecomodder...
Old 12-22-2011, 11:31 AM   #6 (permalink)
is this a 5 speed car?
If so, then I bet it is "desired" by the ECU.
The ECU cannot tell what gear you are in on a 5 speed. And there are less pumping lossses with a higher throttle opening on deceleration with the car in gear. So I bet the ECU is opening the IAC valve to let the car coast "better", and you are fooling it by shifting into neutral.
Old 12-22-2011, 11:33 AM   #7 (permalink)
tru
tru - '05 Ford Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 GMC Sierra Denali
I was suggested by a co-worker to detach the IAC and adjust the throttle position manually so the car idles where you want, not what the general public wants. I just dont know where the dang thing is on my engine lol.
Please let us know if changing it helps, however, i think yours is working as designed.
Old 12-22-2011, 11:37 AM   #8 (permalink)
The IAC will almost always be in the throttle body, which is at the top or "front" of the intake. It will have a plug with a 5 to 10 wires going to it.
If you unplug it on a 1996 or newer car, the ECU will throw a code. My GUESS GUESS GUESS is this will not throw the engine into limp home mode, but it will cause idling issues.
Old 12-22-2011, 11:43 AM   #9 (permalink)
mbrac's Avatar
That makes perfect sense - about the coasting - so I guess I either have to live with it or find a way around it - I try to do allot of coasting to stop signs and redlights - etc - and it the idle is 1500 that whole time - it's just a waste of gas - Oh, and yes, it is a 5 speed. Thanks again for your knowledge on this subject - it helps me make more informed decisions on what to do next.
Old 12-22-2011, 01:13 PM   #10 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
My Canyon does the same thing, and has done it since it was new. The dealer said: "No trouble code means no problem". So I put in a kill switch and eliminated almost all idling.
