Old 04-10-2012, 07:29 PM   #1 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Cool Scuderi files patent for 'split-cycle' engine
Scuderi files patent for 'split-cycle' engine | Fox News
Thoughts?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 04-10-2012, 08:16 PM   #2 (permalink)
Faux seemed remarkably objective for a change.
Scuderi Engine - Wikipedia, the free encyclopedia
I've read about this before; it was all the rage 3 years ago; supposedly they have a fistful of patents already; don't know why this last one is any different.
I've read about how it supposedly works several times and I have to admit, I don't get it. What makes a piston supercharger any better than any other sort of supercharger? On top of that, it's turbocompounded- that's nothing new. So then there's firing at ATDC, which I think is neat, but I don't understand what makes it work in this layout; why couldn't any ol' ICE have that?
Old 04-11-2012, 12:31 AM   #3 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I agree.
Different? Yes. Neat? Yes. Revolutionary? Nnnooooo.
Old 04-11-2012, 01:33 AM   #4 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
A mechanically-driven (belt, gear, chain) supercharger robs power from the engine. Perhaps a piston-powered supercharger provides gains in efficiency ?
Old 04-11-2012, 02:54 AM   #5 (permalink)
And a piston is....
mechanically driven.
I don't know how the various types compare re: compressing efficiency.
Old 04-11-2012, 07:23 AM   #6 (permalink)
Send a message via MSN to markweatherill
Maybe it isn't much more than an excuse for a press release ie they need some more investment.
Old 04-11-2012, 07:30 AM   #7 (permalink)
That's probably it. There's supposedly "millions" sunk into it already... it would make a good Aptera engine.
Old 04-11-2012, 09:33 AM   #8 (permalink)
mechman600's Avatar
A piston compressor doesn't give you a chance to cool it down with an intercooler first. That can't be good.
Old 04-11-2012, 10:00 AM   #9 (permalink)
I've talked with these guys at length at the DC auto show. They do already have a fistful of patents. I'm wondering if they keep filing for new and improved patents to keep the technology from becoming openly available when patents expire. I'm wondering if they just want too much $$ to license the engine.
Some of the efficiency comes from:
A) Super high compression. Like 15:1 or greater in the second cylinder. And different comp. ratios for compression stroke and power stroke (like atkinson)
B) Firing ATDC (don't have to compress during combustion)
C) The potential of an Air-hybrid. You can actually store the energy created under compression braking into a large tank (and feed it back into cyl #2 at a later time).
Old 04-11-2012, 10:34 AM   #10 (permalink)
I don't see where 25 percent more efficiency is going to come from.
a. you can run 15:1 in a traditional engine. same problems, same solutions. variable cam timing is a pretty known technology on an Otto engine, which gives pseudo atkinson already.
b. This one is REALLY weak. you can fire ATDC on an Otto. But in any case, your mean average cylinder pressures will be lower, and mileage will suffer. There is spark advance for a reason.
c. Even weaker. You can do an air hybrid using the main pistons, and you can do an air hybrid with an Otto engine. In either case all you have to is completely change the cam timing - not a trivial matter.
This new revolutionary engine looks a whole lot like a Detroit 2 stroke diesel to me.
