Old 02-18-2017, 04:15 PM   #1 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Idling engines is a behavioral modification problem
Mainstream psychology is looking into how to convince people to shut their engines off: https://phys.org/news/2017-02-behavi...em-idling.html. And showing successful results.
The Following User Says Thank You to JRMichler For This Useful Post:
Frank Lee (02-18-2017)
Old 02-18-2017, 04:22 PM   #2 (permalink)
It seems that a lot of people think starting the engine more will wear the starter out that much faster.
Which isn't true, starter age appears to be the main factor in their failure.
Old 02-18-2017, 06:30 PM   #3 (permalink)
...beats walking...
Starter motors "wear" with every use...use it 100-times more often and it'll wear out 100-times sooner. Mechanical wear is a function of usage.
• Lookup: "bathtub curve life cycle"
The Following User Says Thank You to gone-ot For This Useful Post:
mcrews (02-19-2017)
Old 02-18-2017, 07:56 PM   #4 (permalink)
Dark Egg - '12 VW Touraeg
I think people greatest fear is that the car won't restart for some reason. Even a perfectly good car may have shift or brake interlocks that could confuse you in the hurried, startled moments of, oh crap! It's time to move! Or that after that you end up only making it back to reverse instead of drive and back in to the car behind you. I'm sure all of these things have happened to a great many people (although never myself, my cars just wouldn't restart because they are pieces of junk). It's one thing when the problem or confusion happens along the curb or in your driveway, quite another when there are 20 angry people behind you waiting for you to figure it out.
What would help was some kind of countdown. The crosswalk sign sometimes helps but not always changes on "0", and not always is it your turn to go, and sometimes you can't see it. Also you may not know if this is a 20 sec light or a 2 min light.
Old 02-18-2017, 08:03 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Doesn't really apply to railway crossings as per the article.
Old 02-18-2017, 08:05 PM   #6 (permalink)
Actually I have found that to not be true at all.
When I was in the air force we had a lot of retarded rules that made no sense.
One of those rules caused busy flightline vehicles to be started between 40 and 100 times a day.
But the starters didn't wear out 40 to 100 times faster. They wore out maybe twice as fast for heavy duty trucks and maybe 3 to 4 times as fast on light duty cars and trucks.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Daschicken (02-19-2017), Frank Lee (02-19-2017)
Old 02-19-2017, 06:00 AM   #7 (permalink)
The proliferation and massive abuse of remote start systems more than counteracts any good this- and perhaps automatic engine-off systems- might do. ☯
Old 02-19-2017, 12:23 PM   #8 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
my car has the starter in a good spot, so changing it is not a problem.
And I've learned to use the 20-sec rule of shutting a car down.
Here in finland we idle our cars warm, urgh. But we have pretty cold winters, so thankfully most people use block heaters.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 02-20-2017, 07:16 PM   #9 (permalink)
Team Turbocharged!
Pickups
For cars with auto stop, BMW and Ford quote 3 and 5 seconds as the break even point (I forget which is which).
Old 02-20-2017, 10:31 PM   #10 (permalink)
My current rental is an ecoboost Escape with auto-shutoff. It really does work well, but there are times when it is annoying in stop and go traffic. Fortunately, there is a dash mounted defeat. I think the long term solution is for all cars to go to at least a mild hybrid system. Something along the lines of the original Insight, but with the ability to run on just the electric motor. Such a motor located between the engine and tranny shouldn't be that much more expensive to build, as it would eliminate the need for a separate starter and alternator. Keep the battery size down and it wouldn't be terribly expensive.
