Old 09-27-2012, 08:37 PM   #141 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
many have been sold as a bare PC Bd. and with a parts kit. Never heard a dissatisfaction.
I'm using a double configuration with 4 IGBT modules since a while
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 09-27-2012, 09:34 PM   #142 (permalink)
EcoModding Jack
nimblemotors's Avatar
Horacio, are the boards you had made the same as the BG2A boards?
Do you have them, and the parts, and what costs?
Did you mean to say you have your EV running using them?
I thought I read the fault circuit isn't used?
I have a precharger control that detects a fault, but if the driver can do it without the slow micro handling it, this is better and faster.
thanks, jack
Old 09-27-2012, 09:47 PM   #143 (permalink)
the only difference between this board and the BG2A board is the parts are labeled slightly differently on this one, so you can't just blindly follow the powerex parts list, or you'll end up with parts in the wrong places. it's pretty easy to figure out where the parts are supposed to go though, by looking at the powerex artwork and comparing it to the BOM
Old 10-01-2012, 11:13 PM   #144 (permalink)
the next stage
Now, I am working at the (almost) final stage....wiring the driver to the IGBTs....
Old 10-02-2012, 04:51 PM   #145 (permalink)
how many igbt's are you driving?
Old 10-02-2012, 08:06 PM   #146 (permalink)
2 x 400 A IGBT
This stage I am working with 2x400 A IGBTs
Old 10-02-2012, 08:17 PM   #147 (permalink)
i think using the bg2a board with both vla drivers on it is overkill for 2 igbt's, but that's just my opinion
Old 10-02-2012, 09:02 PM   #148 (permalink)
EVVette - '71 Chevy Corvette Coupe
Isaac is right. 2 vla-501 is overkill for 2 400A modules. Even 1 VLA is overkill for 2 modules. I would use 1 and parallel the igbt's with gate resistors for each module.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 10-03-2012, 01:19 AM   #149 (permalink)
Thumbs up
thank you very much for suggestion, I'll follow your direction..
thanks again Brothers...
Old 10-03-2012, 01:20 AM   #150 (permalink)
how about 2 x 1200A
Gentlemen,
I also have the other 2 IGBTs, each 1200A, can I drive them each? or have to do it paralel?
thanks
