Old 03-29-2017, 08:05 AM   #31 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I've had LEDs that are now on their 4th vehicle. It's a bit of a pain to change back and forth each time, but the ROI is a long term game. I buy good ones (~$40) though.
They also light up the equivalent of 16' earlier than filament bulbs at 60mph. One rear ending avoided will change that ROI in a hurry.
Old 03-29-2017, 09:38 AM   #32 (permalink)
Eco Sol
Shortie771's Avatar
You beat me to it. Good quality LEDs will outlive filament bulbs by a lot. They will pay for themselves in replacement bulbs eventually... It will just take a long time.
That's a very good point about the ROI for not getting rear ended.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 03-29-2017, 03:47 PM   #33 (permalink)
Welcome
the prius uses led taillights and gets better mpg's (in part)because of it.
Tiny, tiny part. Nowadays, the Prius gets average gas mileage for a car in it's aerodynamic class (it just got there first). Consider this strategy: Acquire a set of complete Prius taillight assembies. Add a short boat tail to improve the Coralla's fineness ratio and incorporate the Prius taillights. First gen if you stay with a notchback, or later if you go to a Kamm-back.
For the headlights be wary of the beam pattern. Also, there exist HID projector headlights.
Old 04-02-2017, 01:29 AM   #34 (permalink)
ASV
weirdo
ASV's Avatar
https://www.amazon.com/Nilight-Drivi...9TCN40ZK8Z0GD8
I used just one of these for my scooter
It's very nice to see with compared to stock
Old 11-01-2022, 04:54 AM   #35 (permalink)
CharlesF's Avatar
This is an old thread, but I can't find anything more relevant.
My question is about OLED taillights. I saw some blogs post articles about them being the best option for taillights because they are so awesome. But then, don't they need more power to work?
Like how does this work? Can OLEDs actually make any difference in mpg, or are they just for fancy designs? Maybe someone already had some experience with them
Old 11-02-2022, 08:18 AM   #36 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Typically LED lights require much less power than incandescent bulbs so they are more efficient. But tail lights do not consume much power, so it would take a few hundred years for you to see a return on your investment. LED lights are a fraction of a second faster, I am not sure how much of a real benefit this is.
Some prefer LED's because they are more robust and this is generally the case but I have seen some very bad LED designs that dont even last as long as an incanedescent bulb.
The Following User Says Thank You to teoman For This Useful Post:
CharlesF (11-02-2022)
Old 11-02-2022, 02:18 PM   #37 (permalink)
Large packs of Aliexpress LEDs are basically as cheap as Sylvania incandescent bulbs for replacing already burned out bulbs, but yea I wouldn't bother replacing them for energy savings because they're intermittently used. Headlights use much more power.
Old 11-02-2022, 03:50 PM   #38 (permalink)
Consider any increase in visibility as added value.
Now I'm thinking about adding a separate RGB LED so I can have virual blue dots.
https://mechanics.stackexchange.com › questions › 50296 › what-was-the-initial-idea-behind-those-blue-dot-tail-lights-from-the-30s-to
What was the initial idea behind those "Blue Dot" tail lights from the ...
In taillights with internal parabolic reflectors, the blue dots gave a very vivid magenta color to the taillight when viewed from directly behind. It's actually pretty neat. On vehicles with no reflector inside the taillight housing, the effect was much less pronounced and not worth doing.
https://cargosu.com › the-idea-behind-blue-dot-tail-lights
The Idea Behind "Blue Dot" Tail Lights - #1 Best Answer
A strong theory exists that says that the blue dot tail lights were first created because it was believed that they could cut through the fog on the road better than other colors available on the market at the time. Truthfully, this isn't the worst theory that anyone has come up with.
https://i.ebayimg.com/images/g/dGkAA...HB4/s-l400.jpg
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
Old 11-03-2022, 12:03 AM   #39 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Tried led lights for my brakes. They consume too little power and it trips off my dash. Don’t feel like spending extra and setting up the capacity controller or whatever it’s called. So I put halogens back in. My headlights are another story
The Following User Says Thank You to Phase For This Useful Post:
CharlesF (11-09-2022)
My LED tail light conversion BrianAbington EcoModding Central 52 12-06-2011 07:42 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 02:32 AM
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 09:50 AM
LED lighting goes mainstream! It's at Wal-Mart! bennelson Saving@Home 81 08-07-2010 12:18 PM
Article: Hella LED Headlamp Study TomO General Efficiency Discussion 14 10-21-2008 03:39 PM
