02-21-2013, 01:44 PM
#51 (permalink)
This idea seems to have some merit- especially on my old diesel
Now I just need to find some insulating tape, and also get a thermostat
good work- I'll be interested to see results
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
02-22-2013, 10:33 AM
#52 (permalink)
OCD Master EcoModder
Originally Posted by cRiPpLe_rOoStEr
What did you use for the insulation?
Josh8loop mentioned my "material useage", which was shown in the photos in the first post in this thread.
This is insulating foam "tape", about 1/4 inch or 6 mm thick. Made to be spiral-wrapped around pipe to prevent water condensation on outside of pipe. It works well when used on a valve cover.
Coast long and prosper.
02-24-2013, 04:51 PM
#53 (permalink)
I'd like to see how would it work insulating the oil sump.
02-24-2013, 10:15 PM
#54 (permalink)
It would insulate, all right. Any oil dripping down the sides of the sump might loosen the adhesive backing of the insulation. And you would have to leave access to get at the drain plug for oil changes.
02-25-2013, 12:45 AM
#55 (permalink)
That's for sure. So, I'd stick with my initial idea and eventually make a custom fiberglass oil pan, which is naturally more insulated than one made out of sheetmetal anyway
03-21-2013, 05:01 PM
#56 (permalink)
Don't those (decorative??) plastic shields over our more modern valve covers limit air cooling of the valve cover?
They sure do.
They also cut down noise.
On my car, there's a foam insert underneath (and glued to) the plastic cover.
The foam came off the cover when an injector was leaking though - engine bay temps were VERY high then as it was blowing out hot exhaust gasses.
(High temps as in bonnet touchable, but too hot to hold on to.)
03-21-2013, 06:36 PM
#57 (permalink)
Maybe this is why a lot of OEM's have been covering the engines with those plastic covers for a few years now. Sort of as an air bubble to trap heat?
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
03-22-2013, 11:50 PM
#58 (permalink)
EV OR DIESEL
Subscribed:
Heavily considering this on my TDI swap.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
03-23-2013, 08:20 PM
#59 (permalink)
Which vehicle are you considering to swap a TDI into?
03-23-2013, 09:52 PM
#60 (permalink)
EV OR DIESEL
Not considering, in action.
My golf was totaled in a hit and run.
I purchased a 2003 Jetta wagon premium (every option available in USA in a mkiv vw) and a TDI out of another collision to swap in.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
