Old 04-30-2020, 11:03 AM   #81 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
AFAIK exhaust wrap also allows the catalyst to heat up sooner, decreasing the so-called "cold phase" which is where most of the harmful emissions are generated. Seems ideal for a hybrid, considering its engine would be operating in a more intermittent way in city driving. On a sidenote, besides protecting nearby components more sensible to heat, retaining more heat at the exhaust flow instead of allowing it to irradiate is often claimed to improve its flow.
this is an issue my cat will drop in temp when DFCO happens
Old 04-30-2020, 06:01 PM   #82 (permalink)
Maybe a full exhaust wrap could be considered, as it would also likely allow you to get a grille block while fewer residual heat would be trapped at the engine bay.
Old 04-30-2020, 06:44 PM   #83 (permalink)
unfortunately the cats are in the engine bay about a foot from the engine.
but I did some more looking under it at lest 30% is covered(what can be a belly pan)
i think it would be possible to work with the rear end belly pan
all i would have to do is close the gaps as it's just randoms things that are occupying a lot of space
gas tank on the right and muffler on the left
The Following User Says Thank You to Tahoe_Hybrid For This Useful Post:
Ecky (05-01-2020)
Old 05-01-2020, 08:26 PM   #84 (permalink)
So it seems like a full-lenght belly pan is going to happen...
Ecky (05-01-2020)
Old 05-01-2020, 11:47 PM   #85 (permalink)
i'll have to figure out how to attach it though not sure how i'll do that (using existing holes )
Old 05-02-2020, 02:03 AM   #86 (permalink)
Why do you need to use only existing holes? It's a lot easier to drill new holes and insert rivnuts into them, allowing you to screw bolts straight into them.
Xist (05-17-2020)
Old 05-02-2020, 09:55 AM   #87 (permalink)
i don't want to cut new holes into the frame
Old 05-02-2020, 05:41 PM   #88 (permalink)
Fair enough - but it will make it very hard to do a good job.
Old 05-03-2020, 12:00 AM   #89 (permalink)
what about using recycling bumpers from the side of the road
then i could buy the Newer model year mirrors that are more aero then the old style from 1999.
Old 05-03-2020, 01:15 AM   #90 (permalink)
Originally Posted by roosterk0031 View Post
I also had to replace the MAF pigtail. Swapped MAF sensors between the 3 cars I had at the time the had the same part with no change.
yeah i moved the wires around got 26mpg hyw with a head wind With A/C on
26 is pretty good not even the 2021 can touch that
but MAF wires or it self is having an issue as i messed with it and the SUV performed almost flawlessly
tell i got home after getting gas that is when i started acting up D:
Soldering is cracked or wires are bad
I put positive pressure on the connector worked for 4 hours of run time
unicorn corral
