Old 08-14-2015, 07:13 PM   #31 (permalink)
AC Customs car builder
S10 - '99 Chevy S10 Base
90 day: 23.5 mpg (US)
Purple People Eater - '95 Geo Metro LSi
90 day: 34.76 mpg (US)
Volt - '14 Chevy Volt Premium
90 day: 1680 mpg (US)
Here's a better view. They passed the 500 mile test, still tight.
Name:	2015-08-14 18.09.16.jpg
The Following 5 Users Say Thank You to WindyDrew For This Useful Post:
Cd (03-25-2021), Daox (08-14-2015), MetroMPG (08-14-2015), NeilBlanchard (08-26-2015), pgfpro (08-15-2015)
Old 08-14-2015, 07:19 PM   #32 (permalink)
90 day: 51.82 mpg (US)
Love it!
Reminds me of this thread:
http://ecomodder.com/forum/showthrea...vers-7143.html
Check it for a few more fun images & ideas.
Old 08-14-2015, 07:22 PM   #33 (permalink)
Does the Volt have active grille shutters ahead of the radiator for the gas engine?
If not, you could do a partial or even full lower grille block, depending on cooling location/requirements of the electronics.
Old 08-14-2015, 08:13 PM   #34 (permalink)
WindyDrew: I mistakenly thought you were new to the forum. (It was the low post count.)
Then I looked at your join date. You're an old-timer around here.
Old 08-14-2015, 08:37 PM   #35 (permalink)
Just didn't have much of value to share, until now
Old 08-14-2015, 08:41 PM   #36 (permalink)
No active shutters that I know of. Just a fake upper grill. I'm not sure how much I could block of the lower grill but I doubt the 13 kw I normally require on a flat road builds much heat. I use maybe 50kw of the 110 kw available so I could probably block the entire lower after summer cools off next month. Maybe I'll try it soon just to see what happens when it gets too hot. Then I would know what to look for when modding
Old 08-15-2015, 08:18 AM   #37 (permalink)
Does the volt have overheat protection built into its electronics? If it does not, any grill blocking could get real expensive.
The Following User Says Thank You to pete c For This Useful Post:
Cd (03-25-2021)
Old 08-15-2015, 08:42 AM   #38 (permalink)
There's no way that a car as advanced as the Volt won't warn me before it gets too hot. It is an electric car after all.
Old 08-26-2015, 09:56 AM   #39 (permalink)
R2 - '13 Chevy Volt
Team Volt
90 day: 20764 mpg (US)
Thumbs up Grill block.
I'm also a recent Volt convert...
IIRC, the grill block is shuttered and automatically opens to cool the electronics, battery cooling or ICE radiator as needed. I've never seen mine open... So far I haven't burned a drop of gas.
Subscribed.
The Following User Says Thank You to ocnorb For This Useful Post:
MobilOne (10-08-2015)
Old 08-26-2015, 10:23 AM   #40 (permalink)
Over how many miles travelled in total, ocnorb?
