Old 03-02-2011, 07:05 PM   #41 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Last two full tanks with improved upper grille block :
47.77 MPG
47.24 MPG
Previous 2 tanks without improved upper grille block :
44.70 MPG (improved grille block installed @ half tank)
44.42 MPG
Disclaimer: not an A-B-A test results.
Not sure what to make of those numbers. There is definitely a gain, although I am not convinced it would be as high as 3 MPG.
Old 03-03-2011, 05:39 PM   #42 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
good numbers
i might have to take off my lower block
i have a 4 mile one-way commute and if the weather is warm or theres traffic
temp goes over 200F
(the highest it hit was 215F going up my hill for 10 sec)
temp is fine if weather is cool and i catch all the lights
Past Present Future?
Old 03-19-2011, 09:08 PM   #43 (permalink)
CigaR007's Avatar
Spring is here and the lower grille block is too restrictive. Fan has kicked in a few times over the last couple of days.
I did not increase the opening, but I did build a sort of "duct" to channel the incoming air towards the radiator. I haven't tested it yet, but it should bring down the coolant temperature.
Will post pics tomorrow as it's too dark outside.
Old 03-20-2011, 04:12 PM   #44 (permalink)
CigaR007's Avatar
Here are the pics.
Did a test run, and the coolant remained stable @ 184F to 188F. I intend to close all the gaps, especially the one on top of the sidewalls.
Old 03-23-2011, 07:55 PM   #45 (permalink)
CigaR007's Avatar
Well, seems the lower grille block is too much, even during Spring. Coolant temperature at 205F is too high IMO (207F triggers fan). Much rather have it in the 180F-190F range.
I removed my installation above as it didn't help much. Hit and miss .
Old 03-23-2011, 09:46 PM   #46 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
with all the variables hit and miss is how you have to find what works for your car. "Will it work?" "Only one way to find out"
Old 03-23-2011, 11:36 PM   #47 (permalink)
Grasshopper
good try anyway Cig
Old 03-24-2011, 12:02 AM   #48 (permalink)
CigaR007's Avatar
Well, after some conclusive testing, blocking the upper grille and leaving the lower grille fully open is the way to go for the Echo.
In colder climates, leaving 1/3 of the lower grille open should provide enough cooling.
Time to move on to the next mod; either lowering the car or aluminum belly pan.
Thanks for the ideas and support !
Old 03-24-2011, 04:51 PM   #49 (permalink)
Grasshopper
i would go belly pan
i started doing the front on mine but havent finished
Old 05-14-2011, 10:18 AM   #50 (permalink)
CigaR007's Avatar
I installed a modified lower grille block and it seems to be working quite well. Temps is actually lower @ 184F most of the time.
I averaged 62.6 MPG yesterday on my 30-mile commute and 59.7 MPG for the day (60 miles). Current tank average is sitting at 55.4 MPG.
I strongly believe the new lower grille block combined with higher outside temperatures is helping my fuel economy. Will post pics soon.
aero mod, grille block, toyota echo
