Old 03-31-2010, 11:59 PM   #1 (permalink)
Lowest drag side mirrors
Any sources on testing of the lowest drag side mirrors?
In other words, for a given frontal area, what shape mirror is most slippery?
Long stalk, further from side glass?
Short stalk, partially in wake of car frame?
Bullet shape?
Old 04-04-2010, 01:16 PM   #2 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
I am interested in this topic also.
Just beginning to plan/start aero mods on a 2000 Camry.
I will post if I find anything.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Old 04-04-2010, 03:41 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Otto -
I think these are good candidates :
They can be $70 a pair for a good set, or less than $30 for a pair on flea-bay if you look around.
CarloSW2
American Solar Energy Society
Old 04-04-2010, 07:31 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
What about Chang Ho Kim's boattailed mirror?
Old 04-04-2010, 08:01 PM   #5 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
An other source may be mirrors used on open wheeled or other race cars that could be adapted to ecomoded road cars. They are very small in terms of frontal area and well shaped. I think I will look for some myself now that I thought of it! Thanks for the question.
Old 04-04-2010, 08:02 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
RobertSmalls -
Yup, that's a great one too :
http://ecomodder.com/forum/showthrea...r-10203-3.html
You could probably combine the best of both worlds. A small-enough-to-use mirror with the boattail design. I found a candidate for the mirror housing in a hobby shop. Think R/C model airplane canopies :
E-Flite Canopy: F-15 Eagle DF ARF
The above is *only* a pictorial example, it may not be the right scale. I think you need one to be about 12" long if it is going to contain a 2" convex mirror. Here is one that is 9" :
Great Planes Canopy Patriot/Dazzler GPMQ2255 - Toysonics.com
Imagine the above with the mirror mounted inside the flat interior part.
Neither of the above egg-zamples are egg-zactly what I was hoping to show. If you go into a hobby shop you can find a really good on for maybe $10 or less.
At one point I had an "Easter Egg Mirror", but that had too much refraction from the clear plastic and didn't work well :
The question in all of these "clear covered" mirror designs is whether or not the clear cover interfers with the visibility. The good thing about a "canopy mirror cover" is that the interior side should not have the clear plastic between the mirror and the side window. I just realized that I didn't test this theory in the hobby shop. Next time I go I will take a round-convex mirror with me and do the test. If it looks good, then maybe I will try a new side-view mirror design.
CarloSW2
Old 04-04-2010, 08:03 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
redyaris -
The mirrors in my first post are modeled after those designs.
CarloSW2
Old 04-04-2010, 11:43 PM   #8 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
If anyone finds the universal F1 style wheels for cheap, make sure to share. So far I've found $70 to be the lowest for the universal ones.
Mirror set, pair, F1 Race style, manual, black or carbon fiber look, without heat: Electrodyne, Quality Motoring Accessories
In Reason we Trust
Old 04-05-2010, 12:11 AM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
AeroModder -
(I don't vouch for the quality ...)
Ok, looks like $28 a pair :
00-04 FORD FOCUS F1 BLACK RACING SIDE MIRRORS 01 02 03 : eBay Motors (item 220569231209 end time Apr-08-10 14:05:02 PDT)
CarloSW2
Old 04-05-2010, 01:29 AM   #10 (permalink)
Bwaahahahaha!!! I'd like to see the yarn/smoke tests on that baby... fail!
Me thinks trailing airflow on eggs ain't where it's at either...
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 179 11-10-2022 03:25 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
-- Bye Bye Side Mirrors -- Help me out basslover911 Aerodynamics 11 11-09-2008 02:26 PM
Bicycle side view mirrors? cfg83 Aerodynamics 2 02-15-2008 11:54 AM
