Old 07-13-2014, 06:21 AM   #1 (permalink)
Lupo 3L tyres
I am looking for replacement tyres for our Lupo 3L. They have to be 155/65 R14.
The tyres that seem to have the best rating are (rolling/wet/noise in dB, and listed from cheapest to most expensive):
- Kumho KH27: C/B/68
- Goodyear Efficient Grip Compact: C/B/68
- Pirelli Cinturato P1 Verde: C/B/68
Are there other tyres that I should consider?
Tyres that I have seen recommended, but have lower ratings than the above are: Toyo NanoEnergy 3 (C/C/69), Continental PremiumContact 2 (C/C/70), Michelin Energy E3B (E/B/69), Continental EcoContact 3 (E/B/70), Fulda EcoControl (E/C/67).
Old 07-13-2014, 12:13 PM   #2 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
That's pretty close to the Insight's tire size, which is 165/65/14. Potenza RE92's are considered the champion in that size (possibly any size) as far as raw MPG but are known for high road noise.
What do you want out of the tire? Grip, smoothness of ride, low noise, low rolling resistance?
Michelin Energy Savers have much lower noise and a better ride than the Potenzas, but cause a loss of as much as 5% MPG. Dunlop Enasaves are pretty well reviewed as a Potenza alternative. Non-LRR tires will cause 15-20% loss in MPG in my car.
EDITED. In terms of LRR, of the 3 I mentioned I believe they are Potenza > Ensave > Energy Saver > all other tires available in this size. The Dunlops are probably the most well rounded tire (hurr hurr).
Old 07-13-2014, 12:15 PM   #3 (permalink)
I would rate the parameters: Low rolling resistance, grip, low noise, smoothness of ride.
So low rolling resistance is of highest priority.
Old 07-13-2014, 12:25 PM   #4 (permalink)
As far as I can tell from threads on Insight central, the Dunlops might be slightly less grippy than the Potenzas but the differences are minute in these 3 tires as far as that's concerned.
Old 07-13-2014, 12:26 PM   #5 (permalink)
Which Dunlop tyres are you talking about? I didn't mention Dunlop anywhere
Old 07-13-2014, 12:41 PM   #6 (permalink)
From my first post, I went back and edited it. Here's the thread where I read about them:
165/65/14 Dunlop Enasave:
New 165/65 r14 Dunlop Enasave - Insight Central: Honda Insight Forum
They're the stock tires for the Mitsubishi iMiEV and Mirage.
Old 07-16-2014, 05:43 PM   #7 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
145/80R14 bridgestone B381 ecopias are the best tire I found in my tests...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 08-06-2014, 08:09 AM   #8 (permalink)
I ended up getting Pirelli Cinturato P1 Verde based on various reviews and tests. It was important for use that the tires are usable in wet weather, since my girl friend uses the car for commuting around 50k km/year.
Old 11-26-2014, 02:42 PM   #9 (permalink)
bjn
According to the specs that tire is in energy class C.
I have been looking for low rolling resistance tires in 14 inch, and found this one:
Toyo NanoEnergy2 175/65R14, which is in energy class A. Have you / anyone tried those tires?
How to interpret these energy classes?
Most A-tires are in the area of 205mm wide. Do they roll better than a 145mm class C?
Or are the classes a relative other tires in the same dimension? So a 205mm A tire might roll worse than a 145mm class C?
Old 11-29-2014, 08:00 PM   #10 (permalink)
RPM
RPM's Avatar
JF - '97 Honda Civic 1.5i LS VTEC (EK3)
90 day: 59.68 mpg (US)
The energy efficiency rating in the EU tyre label is a function of the Rolling Resistance Coefficient (RRC), defined in the attached table.
Source: http://eur-lex.europa.eu/legal-conte...9R1222&from=EN
Name:	Screen Shot 2014-11-29 at 11.55.22 PM.png
The Following User Says Thank You to RPM For This Useful Post:
bjn (11-29-2014)
