Old 12-27-2008, 10:16 AM   #1 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Maintenance and FE
A few weeks ago the scenic went to the mechanic for a regular 15000km (9300 miles) maintenance. Since then, the consumption when coasting in neutral is lower than before.
  • Before maintenance the consumption was at 1.4L/100 (168mpg) when coasting in neutral at 60km/h, ie 0.84L/h = 0.22GPH.
  • Since maintenance it's at 1.2L/100 (196mpg), ie 0.72L/h = 0.19GPH.
As the consumption is shown with +/- 0.1L/100, this is at least a 8% saving when coasting in neutral...
(my cars aren't SG2 compatible and the scenic doesn't show the instantaneous consumption under 35km/h (22mph))
From car's manual, any *w40 oil is OK from 0w40 and up. The mechanic uses 10w40 by default and was very astonished that I was asking for 0/5w oil. He didn't had any 0w oil.
I find that improvement too big for a simple maintenance and I think the oil change from 10w40 to 5w40 and the air filter change aren't the only reason to such a big change. Not the lower temperature, nor the higher humidity are helping FE.
What is your experience ?
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 12-27-2008, 01:24 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Do you know what was done besides air filter and oil?
Old 12-28-2008, 05:56 PM   #3 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
I read the invoice again and they :
  • changed the oil & air filters
  • changed the oil (5w40 ELF)
  • verified all the liquid levels and added cooling and windshield liquid
  • verified wipers, breaks and springs
Except filters and oil, I don't see anything that would explain the FE change while coasting in neutral.
Today I had dozens of occasions to look at these numbers : at each city entering I coasted from 90 to 50km/h (56 to 31mph). With a warmer temperature (8°C/46°F instead of 2°C/36°F) and a lower humidity (<60% instead of >90%) I have seen several times a 0.8L/100km while decelerating changed to 0.9L/100km at 60km/h, which would correspond to 0.54L/h (0.14GPH).
Denis.
Old 12-28-2008, 06:14 PM   #4 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Check you tires,
Perhaps as a courtesy the technician checked and lowered the pressure to the door sticker and did not realize you had them inflated for FE.
Tire pressure from 50 psi to 30 psi is going to make a difference you can feel.
Just a thought,
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 12-29-2008, 04:09 AM   #5 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
The FE did improve at idle from 0.22GPH (Gallons Per Hour) to 0.19 (and even 0.14 with a warmer and dryer weather).
Tire pressure doesn't change the instantaneous consumption while the engine is idle when coasting in neutral.
I'm OK that placard will make coasting in neutral shorter than sidewall. Anyway right before my Xmas challenge [1] I verified the tires, they were at more than 3.0 bars (43 psi) and pumped them up to sidewall (3.5 bars = 51 psi).
I got the car at 60000km and I make a maintenance every 15000km, so this is the 5th for me. The calculated idle numbers were consistent until that last maintenance. I can't believe that such a simple change from 10w40 to 5w40 can improve the FE at idle for more than 10%.
Denis.
[1] more about it later, I'm working on the data. You can read comments in my last 2 tanks.
Old 01-02-2009, 03:14 PM   #6 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Quick question to all...
How many change their oil at 5,000 miles instead of the "old" 3,000 mile segments?
Heck, my Mazda6 dealer now says go 7,500 miles but I am hesitant of doing so. I am going to change it in a few hundred miles since I have gone 5,000 miles now but I am just wondering what everyone's interval is ... ?
Old 01-02-2009, 04:34 PM   #7 (permalink)
econ00b
green car - '91 honda civic hb dx
Groar,
Are your findings with the car just started up or after its at operating temp? The lower weight oil should make a noticeable difference on start up because the it doesnt have to warm up as much to achieve its operating viscosity. I know an old van my parents used to have said in the manual to use different oil weights depending on winter or summer. At least thats the only reason that comes to mind, unless your air filter was really really really dirty.
basslover911,
Thats a bit of a loaded question. Its really the same kind of deal as whether to do aero or weight reduction mods.
If you do mostly in city driving, I would recommend changing the oil every 3-4k miles, if mostly highway you can get away with 5-7k. Highway miles are easiest on the engine since it keeps a fairly constant load and isnt being asked to work as hard.
Over the past few months my driving has been about 75% highway, I changed the oil at 5k and I could still see through it, it had barely begun to darken. Huge difference from the old oil changes with mostly city driving and a lead foot. When I would change the oil then after about 3k-3500 miles it would be DARK.
Old 01-03-2009, 01:28 AM   #8 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.64 mpg (US)
I've gone from 3K to 4K to 5K now, which puts me at about 3 oil changes a year. I never drive it less than 5 miles and it gets a fair amount of long trips in. I am in no way concerned that this is too long an interval. Most research I have seen on oil life backs me up. No need to throw away perfectly good oil to meet some arbitrary, outdated standard.
Old 01-03-2009, 06:52 AM   #9 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
My older car (1997) is at 10000km (6200 miles) while my newer one (2001) is at 15000km (9300 miles).
In my older car the oil level begins to lower at 8000km while the newer one arrives at min oil level at 15000km, so I respect these milestones.
I know newer cars are at 20000km (12400 miles) and some have been up to 30000km (18600 miles) but then people were mixing "low maintenance" and "no maintenance"... so newer cars tells you the distance remaining before next maintenance.
Now all that I know is French diesel, but I have always been told that diesel need more maintenance than gasoline. This may not always be the case with newer diesels.
Denis.
Old 01-03-2009, 07:16 AM   #10 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
When the car is at operating temp.
Is it possible a 10w oil isn't 100% synthetic ?
I heard the 5w can only be synthetic. The 5w used (8100 X Clean) is 100% synthetic : MOTUL
The air and diesel filter may also be a possibility, but it was the 6th maintenance and I never saw such a difference.
I plan to visit my mechanic when he is back from holidays to know more about it and see the difference between his 10w and 5w oils. He insisted on the fact the 5w is more expensive and it was 20% more expensive. It may be some magic with some additives in this oil, or some magic from new kind of filter, or...
Denis.
