Old 08-01-2015, 12:52 PM   #51 (permalink)
Xist -- That's all I was saying. All criticism as constructive, just trying to move things along.
...and, good on you.
aerohead -- I'd wondered what the rules would say about head-first position. I've heard bicyclists go supine, but they have to pedal. Maybe prone?
One thing you lose with the more upright driving position is forward visibility. The Varna body is almost like taxiing a tail-dragger airplane.
Have we lost the OP?
aerohead (08-01-2015)
Old 08-01-2015, 01:58 PM   #52 (permalink)
supine
The supine position is used so far,but maybe not where Joan is competing
http://twwhlspls.com/wp-content/uplo...gravity_04.jpg
Old 08-02-2015, 03:49 PM   #53 (permalink)
If you're going to do an exposed-wheel car,an 'automotive' application of the NACA 0015 won't have any remarkable benefit for you.
The center airfoil section in the table below is the lowest drag.It's right in the pressure/friction bucket.
It's like the section at the bottom here.Very good flow.
Just turn the section on it's side like Soapbox Derby cars have done,then treat the top of the body as a wingtip.
Enclosing the suspension system inside struts as the Edison-2 X-Prize winner has done would be great.
Also,the wheel fairings,just as Edison-2.
Thank you Aerohead! i will adapt this shape to the body!
Old 08-02-2015, 03:52 PM   #54 (permalink)
I did a quick search to see if anyone ever calculated the cD of a soapbox derby car. I just found this page, which talks about racers achieving 25-35 MPH.
Apparently, the United States does not have hills like Spain does!
well, the actual gravity racer record is hold by an American guy:
https://youtu.be/Q1ndyA0UW2w
https://youtu.be/olF1WM7TMLM
the record is 84.4 mph!!
The Following User Says Thank You to orengomotors For This Useful Post:
Xist (08-02-2015)
Old 08-02-2015, 03:56 PM   #55 (permalink)
Freebeard, i'm still here! learning a lot from all of you!
Old 08-02-2015, 06:44 PM   #56 (permalink)
Orengo, it is great to hear more from you.
Darcane, can you tell us about your son's racer? Perhaps in a dedicated thread?
Old 08-04-2015, 07:29 AM   #57 (permalink)
the actual dimensions of the soapbox:
-Aerohead, Something like that??:
Old 08-05-2015, 07:21 AM   #58 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
I love this thread so far !
Could you describe a typical race like how many bends and their variety so we could get a good idea of the compromise between speed and handling ( for instance a narrower rear track should help speed through aero at the expense of stability) ?
I am already thinking spring brakes to get energy back after the braking
Old 08-05-2015, 05:14 PM   #59 (permalink)
like that
You're gaining on it!
*Letting air go under the body is a no-no,so dropping the nose down to ground level would be a good move.Here's 'Kamm's' pumpkin seed body at top,notice how he did the nose
For the rear underside,for lowest drag,about a 2.5-degree up-slope angle has been found to be best.Here's Jaray's pumpkin seed of 1922.Really good pressure recovery (1st diffuser on Earth).
If you look above the wheel fairings on the Template you can see the 2.5-degree slope
[IMG]http://i1271.photobucket.com/albums/jj622/aerohead2
/Scan12.jpg[/IMG]
Getting the nose down and gentle diffuser will give you extra stability when at speed.
orengomotors (08-06-2015)
Old 08-05-2015, 10:25 PM   #60 (permalink)
Regen/KERS. The big dogs use a flywheel.
aero, low drag, soapbox, streamlined
