Old 04-03-2012, 07:34 PM   #181 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
i was confused too doax, just gotta buy into his logic to see the explanation....
Originally Posted by mja1 View Post
...Measured target AFR will be 5-15% over the actual, meaning you'll be running slightly lean. If this lean event is not enough for the ECM to add enough fuel to noticeably effect long term fuel trims, you'll net slightly better mpg...
and i think the 'if' will be over in about 2 seconds
Old 04-03-2012, 10:31 PM   #182 (permalink)
truck - '06 Chevrolet Silverado WT
90 day: 22.65 mpg (US)
guys, I apologize about my poor explanation of things, let me make it in the simplest terms I can.
The frequency at the MAF is the same with or without the CAI. The ECM uses this frequency to force a commanded AFR at the O2 sensors.
The MAF will read the same frequency in hertz as before, but with a slightly larger volume of air. The O2 sensor will force a slightly lean condition (*vs a measured/actual AFR*) from what is being commanded by the ECM (unless a large enough volume of air is sensed by the MAP to force engine into open loop and/or change fuel trims, and a number of other factors), if you read it off a tuning device it will say the O2 sensor is what it should be at '14.7' lets say. But this isn't the actual its just being commanded by the ECM. That reading, if you put a wideband in the same exhaust will read a slightly higher AFR than *what the computer is telling the O2 sensors*.
If the ECM/car has stock widebands in the system, like a stock forced induction car, this will be prevented, also if there is no MAF on the car. If you don't believe me then go try it yourself, the MAF frequency should be tuned for the increased air volume of the CAI, when this is done then yes all the warm air vs cold air thermo engine theory that has been talked about becomes true.
...the actual measured AFR will be 5-10% (or on extremely large engines as much as 15%) leaner than what the ECM is commanding.
Old 04-03-2012, 11:39 PM   #183 (permalink)
Team Saturn
are you assuming a larger volume of air due to a CAI? or have some other method of measuring the volume of air?
under what conditions is the MAF reading the same? at idle, cruising at a steady speed, WOT?
i wouldn't expect to see a difference in from the MAF readings until you are at or very near WOT, because untill then the volume of air going past the MAF will be governed by how far the throttle is opened or the IAC.
Old 04-04-2012, 02:42 PM   #184 (permalink)
This is the year
Bug - '06 Volkswagen Beetle TDI PKG1
90 day: 37.04 mpg (US)
F-350 - '11 Ford F-350 Lariat
90 day: 16.23 mpg (US)
I have a hard time believing a narrow band O2 sensor won't be able capture the AFR variation at steady state driving (economy/stoichiometric driving). Sure a wideband may give accurate numbers at cold start up/idle or WOT, but both are closed loop operations. Wideband O2's have wider voltage ranges to detect wider AFR ranges.
Old 05-26-2012, 05:44 PM   #185 (permalink)
broken link
The link for the Civic VX Lean Burn info is broken, the original site appears to be no longer registered. I did find an archived copy at the Internet Archive at archive dot org, if you copy and paste the URL from the article into that site it will pull up the original site that is down. Someone might want to permanently link it somewhere. Unfortunately, none of the pictures were archived; only the text of the article, with the exception of one of the photos of the ECU pinout.
Old 09-21-2012, 10:36 PM   #186 (permalink)
There are more like 80 mods on the wiki now, not counting the disproven ones.
Old 02-12-2013, 02:29 PM   #187 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Just found a typo...
Of all aero mods, a full boat tail will probably have the single largest effect on reducing fuel consumption, though it is obviously more difficult to construct (and will result in more heads turned than anything other mod!).
Should be "any".
Now, it might be difficult but I was wondering if we might order them by effectiveness, money and skill. Could we lump money and skill together, then plot them on a graph with links to the different mods? That would be an easier way for newbies to overview possible mods.
Also, kill switches are much more effective than the listing suggests. Even my boat tail had nothing on some hardcore P&EOC. A 10% (4mpg) difference.
Old 06-12-2013, 05:06 PM   #188 (permalink)
What is the real MPG gain by changing to all synth, motor oil, trans, diff, bearings?
I have to get almost all of this done as routine upkeep on my 1997 Mercedes E300D.
I know it's on the list, but really. Has anyone done a before and after?
If it's on the forum already I couldn't find it. Point me in the right direction.
Thank you.
Old 07-30-2013, 11:31 AM   #189 (permalink)
justme1969's Avatar
Need add GPS
I learned that one last weekend ended up 23 miles out of way with 1 simple misturn then couldnt correct later due to no knowledge of location or area.
Its simple but true savings.
Also brake pad return springs they dont work on every car infact possibly only 1/3 but for old hydro brakes that just piston straight in and out they do help to lessen parasitic brake drag.
Old 03-20-2014, 02:38 AM   #190 (permalink)
Motorcycle mod
In case this hasn't been suggested yet:
Eliminate stock mirrors and put Bug Eyes on your helmet:
BUG EYES Rear View Helmet Mirrors
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 11:57 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
