I had mine set at 0.02 degree toe in with the stock control arm bushings having flex in them and it worked great. With non flexible bushings I may have to alter the alignment some to keep alignment good. The alignment is worth a massive amount of rolling resistance if you can get it close enough to zero.
My last Ecotec project...
