06-02-2017, 09:59 AM
#11 (permalink)
What the hell would you want to do with a vuvuzela on that engine?
Originally Posted by OP
- bellmouth the induction snorkel
- bellmouth the exhaust tip
I was thinking plastic would be easy to cut. In the event, I used a metal air horn I've had (and never used) for 20 years. The pieces are cut, when they are installed I'll post up the pics.
06-02-2017, 10:30 AM
#12 (permalink)
Volvo-driving MachYeen
Biodiesel is easy peasy on the engine.
commercia diesel in the 70'/80s was absolute s**t compared to modern biodiesel. Lot of impurities.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
The Following User Says Thank You to Fingie For This Useful Post:
06-03-2017, 01:43 AM
#13 (permalink)
Since it's an old IDI it can run even on vegetable oils quite easily. Volkswagen had even tested it with soybean oil in Brazil during the 80s.
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
06-03-2017, 02:47 AM
#14 (permalink)
I quoted the owner's manual and the attendant suggested 1%. I'm more concerned about things like the trip odometer being inoperative. It's nice to know I have a path to petroleum independence. Maybe I can fit a grease rendering plant in the back under the lift-back?
All I did today was wash it and drive it. I deleted the passenger-side wiper and replaced the blade on the driver side. Before it goes out of town, I need to do a wheel alignment and get a pair of tires.
06-03-2017, 08:52 PM
#15 (permalink)
That's exactly why I like old-school Diesels
I've already seen some early water-cooled Volkswagens, not just Passat/Dasher, converted to single-arm wipers. Weight savings are roughly negligible, but it still leads to a minor aerodynamic improvement, especially when set to stand up while not in use.
06-04-2017, 05:04 AM
#16 (permalink)
Primer is still paint!
Found one! Here you go, a nice parts car for ya!!!
1981 Volkswagen Passat/Dasher
06-04-2017, 12:02 PM
#17 (permalink)
I am running b20 in my 6.5 GM Diesel. I had to replace the 1/8" return lines that run from injector to injector. The mechanical lift pump has held up so far.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
06-04-2017, 08:21 PM
#18 (permalink)
Biodiesel is often used to enhance the lubrification on pumps and other injection components.
06-05-2017, 12:35 AM
#19 (permalink)
I'll burn through this and try something else. But at 10 gallons x 40mpg it may take a while.
I've cut the bellmouths, but I'm concerned with 'fettling'. The exhaust bellmouth has excessive taper and actually forms a anti-reversion valve. These may not be the parts I'm looking for.
Thanks for the suggestions, but that '81 has two too many doors.
06-05-2017, 12:16 PM
#20 (permalink)
Freebird, Shell sells B20 without Oregon road tax. It is not a Shell product so it may not be available at all stations. $2.299 mid valley.
