Old 09-19-2008, 09:36 AM   #1 (permalink)
Miata report
This is really a follow-up to "My wife can't drive". I finally used up most of the gas in that tank and filled up yesterday. The car only used 9.3 gallons in 339 miles! That's almost 36.5 mpg. The combined EPA estimate is 23 mpg.
I managed this with everything stock (except the tires were pumped up), 100% in town driving, top down most of the time, and about 50% of the driving at night. There is no instrumentation except my highly calibrated and sensitive butt.
Now it's got me wondering just how far I can go if I ......
Old 10-10-2008, 09:37 AM   #2 (permalink)
Lex - '02 Lexus IS300 Sedan
90 day: 19.77 mpg (US)
Turblow - '88 Mazda 323 GTX
Subie - '96 Subaru Impreza Outback
90 day: 21.15 mpg (US)
I find it just too damn tempting to get on it. Especially with the shortened gears. I also have the ECU overclocked for 8k redline...which does not help midrange torque due to either Timing or Fueling adjustments being incorrect for max power... With that said, being abusive in a miata gets you like upper 20s! And that is a motor with 165k abused miles!
Old 10-11-2008, 12:26 AM   #3 (permalink)
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
my miata motor has around 500 miles on it and I get 10mpg. Be happy
Old 10-11-2008, 11:30 AM   #4 (permalink)
That is my kind of miata....waiting for the EMs to attack!
Old 10-11-2008, 01:30 PM   #5 (permalink)
'El Misil' - '91 Opel Calibra 2.0i
Last 3: 29.02 mpg (US)
My Megasquirted NA 1.6 makes 4.8~5.2 l./100 (45~49 USMPG) when driving like the granny at 90kph (55 mph) in fifth, this with a 14.5:1 AFR at those conditions.
At higher speeds however the bad aerodynamics take their toll, 150kph (91 mph) mean ~10 l./100 (23.5 USMPG).
I made some small experimenting on cruise leaning and this engine runs fine leaned to 18:1 in cruise, although of course throttle response sux bigtime then.
Also this engine loves advancing the ignition below 5500 rpm & 75 kPa.
Old 10-11-2008, 01:56 PM   #6 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
I wish I fit in a miata (but I don't wish for the insurance the car would cost me )...... With the soft top up, my head pokes through the canvass I have an unfortunately long "neckular" region I do fit if I slouch down/lean back uncomfortably - but I'm not going to do that unless I'm getting 400+mpg as a result of it
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 10-13-2008, 09:14 PM   #7 (permalink)
I'm 6'5" with a 32" inseam (and could stretch to look over the windshield of an early miata). There are a few ways I've heard of fixing a miata/MX-5: Removing stuffing from the seat, replacing the seat (perferably with a drag-racing seat that bolts to the floor), and replacing the seat and removing the "ribs" at the back.
Personally, in the unlikely event that I consider this when I buy my next car, I would find somebody who has done these modifications (try your local autocross) for a "test sit".
I don't normally envy "the little people", but they do get at least one more cool car.
Old 10-13-2008, 09:58 PM   #8 (permalink)
My 1995 geo metro is $15/more a year in insurance than my 94 miata. my 2001 miata is not much more and its my primary vehicle with collision.
and im 6'1, the miata is not a tough car to fit in. i have friends that are 6'4" and 230 lbs that race with me. and beat me soundly.
Old 10-14-2008, 01:45 AM   #9 (permalink)
II do fit if I slouch down/lean back uncomfortably - but I'm not going to do that unless I'm getting 400+mpg as a result of it
That may be your problem: what you call slouching down & leaning back is the normal semi-reclining posture that most sports car designers intended. I confess I've never sat in a Miata, but I've owned a bunch of other sports cars including an Austin-Healey Sprite, and at 6' I fit quite comfortably.
Indeed, I find the semi-reclining posture both normal and comfortable, and the bolt-upright seating of American cars & SUVs not comfortable at all. I suppose it's all in what you're used to...
Old 10-14-2008, 11:19 AM   #10 (permalink)
MechE
Alas, this is a case where total height doesn't matter so much as where that height is located.... I have relatively short legs - so we might be close in height while sitting, but if your legs are longer than mine, I'm going to be taller sitting :/
I guess I should say that I have no clue about the newer mx-5....
I've got no problem with reclining... I ride a recumbent and am always wanting a more supine position. But slouching, no - that's fatiguing as your body shouldn't be offset. I do fit in a Lotus Europa (such that I get full vision), which is much smaller than a miata (and much more reclined). It's all a matter of anthropometric design.
So, maybe I shouldn't have said leaned back in my original post to avoid confusion
Report any web site bugs here Peakster Forum News & Feedback 609 04-21-2017 11:34 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 36 08-05-2013 11:25 PM
Cnn Major Report On Hypermiling Tonight! dsq EcoModding Central 13 06-03-2008 03:12 PM
Report on car culture: Canadians driving more; walking, biking less. Suburbia blamed. MetroMPG General Efficiency Discussion 6 01-24-2008 03:55 PM
