Old 11-17-2010, 12:36 PM   This thread is in the EcoModder Project Library | #1 (permalink)
MINI Cooper S rear diffuser w/ underpanel
From the rear valance, my design extends back 26" to the rear subframe and is nearly 4ft wide. From the subframe, the underpanel begins a gentle rise at the same angle another 12" back. So we are talking about nearly 12 square ft of area acting on the air.
A and B of diagram above, the best angle for drag reduction (CD) is from 2 and 4 degrees.
A (like mine), the best angle for reducing lift (CLR) is 6 degrees.
B, the best angle for reducing lift (CLR) is 11 degrees (at the expense of increased drag)
Made out of black coroplast, total weight with strakes, just over 4lbs.
Visual indication of how far back the 6deg rake goes back to combine with the flat underpanel:
Now for the shocking results!
I drive the same commute to work everyday and usually average about 26-27mpg. After logging 106 miles with the diffuser, I filled it back up with 3.538 gallons....that's now an avg of 29.9mpg!!!
Joe
The Following 4 Users Say Thank You to curv872 For This Useful Post:
jime57 (11-18-2011), lamb.chop (07-13-2012), mcguire (05-09-2011), MrMiata (11-17-2010)
Old 11-17-2010, 01:22 PM   #2 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Awesome! Beautiful diffuser. How did you close out the coroplast edges, and how did you mount the strakes?
Old 11-17-2010, 01:27 PM   #3 (permalink)
Thanks!
Just used painters caulk to close the trailing edge...I may revisit to clean the edge a bit more. For the strakes I had a brainstorm...they are coroplast pieces folded in half so bottom edge is perfectly flat...which also made them much more rigid. They reside in aluminum C channel adhered with Gorilla Glue.
Old 11-17-2010, 01:57 PM   #4 (permalink)
Here is a view of the top side:
Old 11-17-2010, 03:57 PM   #5 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
I'm jealous! I'm certain my Fit would benefit from a rear diffuser, and it would be relatively easy to do. Please let us know if your improved results hold up over time.
Old 12-22-2010, 01:18 PM   #6 (permalink)
Another 302.1 miles, this time 26.9mpg (some of which was stuck in traffic, so i'm happy).
Old 12-22-2010, 03:47 PM   #7 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Nice work! It looks great and I think you will continue to see good results. I did a similar thing from just behind the catalytic converter and I am amazed what it did for my mpg. I may have to add some strakes like yours. I used some thin aluminum roof flashing to fill in between the fender liner and the diffuser. I'm in snowy Colorado and I didn't want that filling up with slush and snow.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 12-22-2010, 04:38 PM   #8 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
The area where you put your diffuser was just open chassis before? Presumably it meets your belly pan on the leading edge...?
It looks like a really nice job, I hope I can make one just as nice for my Beetle.
I'm not coasting, I'm shifting slowly.
Old 12-26-2010, 08:19 PM   #9 (permalink)
Euro Golf 4 TDI s.e.
Mario_Marques's Avatar
Golf4 tdi "115" - '01 VW Golf TDI Sport Edition
Diesel
Send a message via MSN to Mario_Marques
Really nice work! Very clean, it looks life factory car!
Tuned VW Golf Mk4 Tdi, Euro spec!
AJM engine swaped by ASZ and many other goodies
Old 01-16-2011, 11:51 AM   #10 (permalink)
After more logging, on average, my freeway mpg has increased 1mpg to 27mpg. I'm very pleased with the results!
2004 MINI Cooper S - Improving Aerodynamics iplaysdrums Aerodynamics 90 08-08-2012 02:13 AM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
rear diffuser build thread LeanBurninating Aerodynamics 24 06-06-2009 08:32 PM
