Old 12-28-2024, 03:41 AM   #11 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
If you go for an air dam follow cowmeat's (IIRC) example:
A central jet down the underbody is beneficial (apparently) and is less likely to high-center on wallowed-out gravel roads.
edit, a full width splitter no deeper than the front bumper with upturned winglets for create air curtains might be worth considering. Something like the Honda example with the tire deflectors inverted.
That's my old Civic! Nothing was properly tested, but MPG kept going up. I have no idea if it was the mods or my driving! I had multiple mounting holes for the license plate. As pictured was good in most conditions at moderate speeds. I had to open it up a lot more at highway speeds. It was fully closed in the winter.
https://ecomodder.com/forum/showthre...gon-37759.html
Throttle stop testing can be used to test changes in drag.
https://ecomodder.com/forum/showthre...rag-38322.html
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
freebeard (12-28-2024), y2kbug (12-28-2024)
Old 12-28-2024, 04:05 AM   #12 (permalink)
Misattribution at #2 corrected. I found that in an old thread and squirreled it away in an album.
Were those deflectors made from conveyor belting?
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
Old 12-28-2024, 01:43 PM   #13 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Yeah, specifically baler belting from Tractor Supply. Easy to work with. I should try something similar on the Insight. Honda put little deflectors on the Insight, but bigger might be better!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 12-28-2024, 09:47 PM   #14 (permalink)
Y2kbug
y2kbug's Avatar
1999 corolla - '99 Toyota Corolla CE
90 day: 47.1 mpg (US)
03 dakota v6 2wd auto - '03 Dodge Dakota
Team Dodge
90 day: 19.18 mpg (US)
Got material for underneath the corolla. Currently waiting for more car parts then i can put the engine back together. I am getting the cooling system working properly before i start blocking the radiator off. The fans were running when the engine was cold.
The Following User Says Thank You to y2kbug For This Useful Post:
Gasoline Fumes (12-30-2024)
