Old 11-19-2014, 11:08 AM   #1 (permalink)
Emerald - '97 Honda Civic CXi
90 day: 40.13 mpg (US)
Talking MPG optimised header ideas
So, I've been thinking about building an MPG-optimised header for my civic CXi... (Why? To see if it works, of course ) probably will be a while before I make a start on it even if I do decide to do it of course, given I have 1000 other things to and haven't even gotten around to installing my MPGuino yet but I thought I'd throw a couple of ideas out there. Posting in Unicorn Corral as it's a potentially controversial suggestion and, of course, it may remain mythical due to time / money constraints.
Why it might work:
  • I'm not talking about fat "high flow" headers off ebay or from a performance shop, this would be specifically designed and built to optimise low rpm torque (without sacrificing too much top-end of course - having the same peak power as stock would be fine by me).
  • I've heard the VX has a specific header designed for efficiency, but looking at it, it's no great prize - short cast iron pipes straight into a cat, the only thing it seems to have going for it is small primary runner diameter. Oh, and a small amount of exhaust pulse overlap from the 1-2, 3-4 pairing *may* help the scavenging of cylinders 1 and 4, but it's dubious.
  • "tri-y" or 4-2-1 headers can enhance low-end torque as well as high-end. Of course, people tend to measure at WOT, but if the torque is higher at WOT then presumably the original torque will be available at some value of partial throttle.
  • We’re basically unrestricted with exhaust header design here, as long as you don’t eliminate the cat, oxygen sensors or other emissions equipment - and the cat on this car is the ‘under the body’ kind, not the sort that sits right on the exhaust ports, which makes longer tuned pipes a real possibility.
Background, based on a bunch of internet reading (feel free to jump in!):
Conventional wisdom is that short fat primaries are good for top-end rpm, while long thin ones are good for low rpm. However, it seems that within the 'butter zone' of primary diameter where you're neither choking the engine nor slowing the exhaust excessively, going a little smaller hurts the top end less than going larger hurts low-end torque.
There are two traditional designs, the 4-1 (all cylinders collect at one point) and the 4-2-1 (pairs of cylinders are connected using Y merge junctions, then the resulting two runners are connected using a third Y merge). The 4-1 can be tuned for a high and narrow peak power band but can sacrifice low-end torque even compared with a stock manifold, while the 4-2-1 apparently can give smaller gains across the board, including the low rpm range, at the expense of some peak power.
Equal length tubes, again, can be used to optimise for specific rpms, while slightly unequal lengths can spread out the resonances and produce a smoother torque curve.
At each Y merge in a 4-2-1, it’s recommended to step the size of the tube up slightly to cope with the combined flow - 15-30% in area seems to be recommended Y merges for ’street’ headers, though it’s more important with the last Y, as the first ones should have exhaust pulses coming in at 180 degree phase to each other (360 degrees of crank rotation). See http://coneeng.com/pdf/Area_Calculation_Table.pdf
Stainless steel is a better insulator than mild steel, and ceramic coating helps even more - this is important because apparently keeping the exhaust speed up is vital for scavenging especially at low rpm, and gas that cools gets smaller and therefore slows down.
A newish development appears to be a 'hybrid' / 'long tri-y' design, utilising primary runners similar in length to a traditional 4-1 design (generally much longer than the primaries in a 4-2-1) - or even longer, with a step in the primary diameter, and longish secondary runners. Putting a step from smaller diameter to larger apparently helps stop reversion (high pressure reflected exhaust pulses going the wrong way) as well as providing an extra reflection point in a longer runner. There are also ‘reversion preventers’ out there that have a step followed by a gentle taper back to the original size, but the jury is still out on them.
Another 'new' idea is a slight 'restriction' in diameter at junctions to produce a greater venturi effect in sucking out exhaust gasses from the other branch.
There is also a set of simple formulae I've found in various places on the webs which are 'guaranteed to spit out something useful' as a header design, which are implemented in this calculator here.
Design:
Using the above calculator, with values of
Exhaust Open BBDC. = 60
Exh close ATDC. = 20
CC of one "Cylinder" = 400
at 5800 rpm (roughly peak torque for a honda D16)
5800rpm (peak torque)
P = 32”
primary ID = 1.42”
P1 = 15”
P2 = 17”
secondary ID = 1.86”
CL = 5.6”
TP ID = 1.91”
TL = 29.8”
at 2400 rpm (5th gear at 100kph, a nice highway cruising speed)
P = 82”
primary ID = 0.91”
P1 = 15”
P2 = 67”
secondary ID = 1.198”
CL=3.6”
TP ID = 1.23”
TL = 81.8”
… and now for the hybrid ‘long-runner tri-y’ mashup. Note that the formula & calculator always use 15” for primary length, apparently “this is the best length” or something.
So, the trouble with primary diameter… the actual exhaust ports on the engine are oval 1.75” x 1.3125”, which is similar in area to a 1.5” ID tube - the above equations suggest anything over this is a waste of time and ideally smaller would be good, but we don’t want a ‘step’ in the wring direction, so 1.5” ID it is.
The primary length to the first set of Ys (our ‘P1’) is then the ‘P’ from the 5800 rpm calculation - 32”. Of course, many sources are quite insistent on the ’15 inch’ thing, and it would be nice to take advantage of anti-reversion effects, so we may as well put a step there, out to 1.625” ID, which is the next standard tube size.
At the first set of Ys, we don’t want too much increase in size (see above), so we only go up to the next standard size, 1.75” ID (area increase of 16%). This is about 10% less area than the formula spits out for 5800rpm, but hopefully should be OK.
Now, the total header length for the 2400rpm calculation is pretty darn long, with P=82” - I don’t like the idea of trying to put the last Y all the way back there, because I’d probably have to move the cat, which I’d rather not. So rather than that, I may as well use the cat as the last reflector for the 82” resonator, and bring the last Y forward a bit… so we can put the last Y at, say, 75” and run a 2” ID collector, with a restriction of around 1.875” (15% increase at the venturi, total step up of 31%). References say that you can almost ignore everything after the cat due to its damping effect on resonance, so I will
Sanity checks:
Ebay headers for D16s appear to have primaries of about 1.75” - this probably makes fabrication easier (you don’t have to dolly the tubes out to match the ports, you can just weld round tube straight on), but it has to be hurting the low RPM power, based on the header formulas etc. (‘serious’ performance headers are larger, but intended for racing with heavily modified engines) … even 1.5” is more appropriate to 6500rpm according to the calculator, but given the port size I think it’s the smallest that can reasonably be fitted.
On the other end of the scale, some info on stock manifold primary tube sizes would be interesting for comparison - however, I strongly suspect that a nicely fabricated mandrel-bent ceramic-coated header with ballpark sensible tube sizes is going to flow nicer at any speed the low cost cast iron jobbie even if the length is a bit longer and the tuning isn’t exactly spot-on. Well, I hope, anyhow.
I’m pretty sure this will all fit, but getting that extra length before the cat will need some interesting design - I’m thinking a ‘ramhorn’ style manifold, in the style of the “k-tuned” headers might do it… luckily I quite enjoy TIG welding
Wrap up:
Crazy idea I know, and I have no idea if or when I’ll get time to try it, but it’s fun to play around with. What would be quite nice is to get access to some 1D exhaust simulation code to validate the above design, but the software seems to be on the “very expensive” side. On the other hand I think the design above looks pretty sensible (to my inexperienced eye), so the old “try and see” approach may just work.
Old 11-19-2014, 11:21 AM   #2 (permalink)
I wouldn't Unicorn this; certainly it can work.
Old 11-19-2014, 12:46 PM   #3 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Sounds like you have already done a ton of homework on the matter and have probably thought it out more than the most header companies. In their defense, they plan to sell to a certain group of car owners who are typically runneing higher RPM than is necessary so the larger tubes are more than likely ideal for the market. Having a Honda you have the wonderful world of used parts at your disposal, I think the easiest way to try this is to buy a used 4-2-1 header and make new primaries. If you can't bend pipe, maybe just weld in smaller tube on the straights for a "quick" test mule piece. Either way I think it could be something worth looking into, many people with small block V8s have claimed increases in MPG after installing headers. Whether or not the Honda manifold chokes the engine as much as the old Chevys did is unknown but the principle is still there.
FWIW I've heard that some of the best custom made headers have Venturis because of their benefits. These are most likely performance benefits but just might help MPG too.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
Madact (11-19-2014)
Old 11-19-2014, 02:58 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
I'd go with variable geometry - for better everything.
Old 11-19-2014, 03:52 PM   #5 (permalink)
Couple of notes: is there room for the length you'll need under the car? Probably the prime reason OEM still makes cast headers. Some empirical data suggesting having the tube resonate at your desired rpm increased flow. Have you incorporated anti-reversion? I have also seen data suggesting flow was similar to a concept called "hull speed" in sailboats.
I say go for it, doesnt look unicorn to me.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
Madact (11-19-2014), serialk11r (11-19-2014)
Old 11-19-2014, 04:45 PM   #6 (permalink)
You'll find that most of the headers you can find are designed the way they are to fit inside the engine bay or to work with the stock downpipe or something, not performance. Exhaust is hotter and under higher pressure than atmospheric, so generally you want rather long headers compared to stock for any reason.
I would just buy a budget header that the go-fast crowd has had good experiences with (they'll post dynos and stuff) and the worst that could happen is that you save a little weight and you gain a couple horsepower. Stock headers suck, period.
If you want to go "variable", one thing to try is a throttle plate inside the exhaust. Honda did it on a motorcycle before I believe, it adds restriction but gives them the ability to tune the harmonics a bit to prevent reversion.
Old 11-19-2014, 04:58 PM   #7 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Very interesting. Mazda skyactive engines have revised chassis tunnels to accomodate long headers. Its supposed to keep hot exhaust gas reversion from messing up the high compression. Yeah, why not do to the exhaust what they do upstream in the intake with valving. There seems to be some issues with the valving being robust enough on both ends with some diesel makes. Would an exhaust valve introduce too much drag in this example?
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 11-19-2014, 05:20 PM   #8 (permalink)
undeRGRound's Avatar
Why it might work:
Design:
P = 32”
primary ID = 1.42”
P1 = 15”
P2 = 17”
CL = 5.6”
TP ID = 1.91”
TL = 29.8”
P = 82”
primary ID = 0.91”
P1 = 15”
P2 = 67”
CL=3.6”
TP ID = 1.23”
TL = 81.8”
Sanity checks:
Wrap up:
I skimmed over this, most looks pretty good. But I would not exceed exhaust valve size (in a 2 valve) for primary pipe size. That rule of thumb works exceedingly well for S/R (hot street, mild race) setups. If you are really looking to eco-mod with a custom header, smaller is better and 1.75" primaries are BIG. A better bet would be an after-header setup like the "acoustic supercharger" system, but it is not available for many cars.
My son and I built one (him mostly, high school shop class) I will see if I can scare up a pic. But remember, it is for a V6 or V8 setup as constructed.
Old 11-19-2014, 05:44 PM   #9 (permalink)
Just a general reply to a few different posters:
The 'Unicorn Corral' part is also somewhat to do with the likelihood of this bubbling up to the top of my projects queue any time soon... that may change of course...
Yes, I'm looking at 1.5" primaries, it's the smallest size that matches the port area.
Great idea about using half of an ebay 4-2-1, that just might work.
Planning on fitting it by using a "ramshorn" layout at the exhaust valve - have yet to measure though.
Variable geometry is fascinating, but I'm at the limits of finding good design info on long 4-2-1s as is... might keep this one 'simple'
For fabrication - I love TIG welding, and mandrel bends aren't stupidly expensive (see ECS engines for example). Also there's a local shop that does CNC mandrel bending for reasonable prices. Will see how I go.
Old 11-19-2014, 06:12 PM   #10 (permalink)
Should be the best case
We always strived to avoid a "Reverse Step" or neck down with a step in exhaust ports.
Don't think I had any input here, but splitting a 4-2-1 into two 2-1 headers and then running them into an X-Pipe would achieve the ASC design.
Here are the pics I promised, all for the bikes but it applies most to a 4 cylinder
ID:	16450   Click image for larger version
Name:	ASC wheely.JPG
ID:	16451   Click image for larger version
Name:	ASC Harley.jpg
The Following User Says Thank You to undeRGRound For This Useful Post:
Madact (11-19-2014)
