Old 05-12-2013, 10:42 PM   #1041 (permalink)
1993 Pace Arrow 30 ft
I'm late to the party. I have a 1993 Pace Arrow RV with a 454 chevy fuel injected. It has ODBI so it looks like the device that has been developed is what I need. Where can I order one, or do I have to build one?
Thanks
Old 05-12-2013, 11:02 PM   #1042 (permalink)
Are you still selling assembled units?
Old 05-12-2013, 11:06 PM   #1043 (permalink)
That site will not open for me.
Old 05-13-2013, 12:10 AM   #1044 (permalink)
Prius 5 - '20 Toyota Prius Standard
90 day: 63.6 mpg (US)
MPGuino trip computer - MPGuino - get assembled mpguino from here!
Old 05-14-2013, 09:55 AM   #1045 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
And here: http://mthtek.com/mpguino.php
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 05-19-2013, 03:13 PM   #1046 (permalink)
I am looking for where to draw the VSS signal on a 2009 Toyota Matrix with 1.8 liter engine, anyone else have anything like this. All my research has found nothing solid. A wiring diagram would be helpful.
Old 05-19-2013, 04:05 PM   #1047 (permalink)
I got my vss signal from the back of the speedo on my mitsubishi lancer so this may be an area to investigate in your search for wiring diagrams
Old 04-03-2014, 02:19 PM   #1048 (permalink)
The Beast - '93 Fleetwood Flair includes kitchen sink
90 day: 9.2 mpg (US)
The Bigger Beast - '03 Winnebago Sightseer Motor Home
MPguino in a Fleetwood RV
Thanks
I have a Fleetwood flair 26 ft. 1993. The "Beast"
CrazyComputers - Information about your Computer
I have an article about the "Beast" there. Look on left side for the link.
I have installed a MPGuino for several years now. (A purchased version)
I resorted to buying a Jcars module to square up the injector pulses.
I have been trying since to calculate an accurate MPG reading.
With a 100 gallon tank makes it a problem. A full tank test is like 2-3 days of driving. 700 to 900 miles (Or more).
The VSS pulses/mile came out to 7847
The Micro sec/gallon is 342228128
I left all other things at default.
The problem with the setup is the 'Guino lies! The mpg shown at 50 mpg is 8 but the mpg at 70 is 10-12. If you follow what happens, then I begin to chase the mileage by driving faster. Not good. I force myself to drive between 50 to 55 MPH. Anything faster kills the mpg.
My actual best mileage, no toad, is 20 mpg. This happened only once, but I've seen 15 mpg before.
I usually get 10mpg now, but I think the ethanol is killing the better mileage.
I like Shell regular. 3 mpg better.
Another thing that I notice is the instant fuel mileage goes to 999 when I get more than 75% throttle. This tells me the calculations quit in that circumstance.
I don't have any source code to try and figure that out. Maybe dcb can help there.
here is the info I get with the 'Guino is how to drive the "Beast".
#1 accelerate briskly to 45 mph. Lift the throttle to get into 4th gear, clutch locked up. This gets you rolling and get the rig into the best mpg.
#2 Ease on the gas to get up to 55mph. Feather the gas to reset to lean burn.
Check the mpg often and lift and depress the gas to reset to lean burn. You can see 2 to 5 mpg improvement.
#3 Gently speed up to go up a hill. The trick here is to hold the throttle perfectly still while climbing. The engine will hold lean burn and you will slow down some but crest a moderate hill in good mileage. If you press down the pedal you will jump out of lean burn to like 3 - 4 mpg! Just lift momentarily and press down to coax it back to better mileage.
#4 On a big hill I just let the tranny shift down and climb up at whatever mileage I get. Just be sure to lift when starting to crest the hill. Then coast down the other side.
While coasting down a hill the 'Guino says 999 meaning the injectors are off and no fuel is used. I have found if you let the speed drop too much you will use a lot of gas speeding up. Just apply light throttle to hold the speed you want.
I hope this helps. You won't need a 'Guino by following these tips. If you install a vacuum gauge it will show you what the 'Guino does.
The above applies to about all vehicles.
You can order a MPGuino plus the Jcar module. You have to solder the Jcar parts. It is a nice kit with lots of instructions. It comes from Australia and costs about $30.00
Old 04-03-2014, 04:12 PM   #1049 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
Originally Posted by CrazyLee View Post
...The problem with the setup is the 'Guino lies! The mpg shown at 50 mpg is 8 but the mpg at 70 is 10-12. If you follow what happens, then I begin to chase the mileage by driving faster. Not good. I force myself to drive between 50 to 55 MPH. Anything faster kills the mpg....
...Another thing that I notice is the instant fuel mileage goes to 999 when I get more than 75% throttle. This tells me the calculations quit in that circumstance...
So if you apply 75%+ throttle, the display instantly pegs at 999? Sounds like your throttle % is affecting the MPG calculation, not necessarily that it "quit" but that the calculation is picking up the throttle. I'm wondering if there isnt' a wiring problem.
Old 04-03-2014, 06:02 PM   #1050 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
A wiring problem or perhaps some of the other pre-sets need switched. It's been a while since I worked on/with the MPGuino, but my first guess is wiring.
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 10:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 06:23 PM
