Old 05-17-2014, 07:47 AM   #1 (permalink)
Slow Silver - '09 Chevy Cobalt XFE Coupe
90 day: 37.56 mpg (US)
GMC pickup - '86 GMC C1500
Hephaestus - '09 Kawasaki Vulcan 900 Custom
90 day: 47.13 mpg (US)
Multiple Throttle Plates
While I was cleaning/rebuilding the carburetor on my old truck, I thought about how it works as compared to the eTB of my car. I remember from experience and the handy-dandy Haynes manual (best 40$ you can spend IMO), that the secondary throttle plates dont open until the engine looses vacuum. So the old Q-Jet would operate at normal temps and cruising as a small two-barreled carb at WOT, which is what made it so efficient (for a carb). It was only when pedal to the floor that the HUGE secondary's would open to give the engine all 650cfm the carb has.
So my query is this: If a 4-barreled carb operates as a small, unrestricted two-barrel at anything below WOT, would a multiple throttle plate system be of any use to a modern EFI? As in, staged throttles which could provide *unrestricted* flow but still not full power flow. If that makes any sense?
Anyway, that old truck would do 16-18mpg so long as I kept it about 60mph, I thought that was alright for a brick of steel as old as me and no overdrive.
Old 05-17-2014, 09:28 AM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I dont think so. With efi the computer keeps a specific ratio of air:fuel. Having a smaller throttle would limit power but the ratio would.be unchanged. Kind of like the testing done regarding dirty air filters on efi engines.
The Following User Says Thank You to ksa8907 For This Useful Post:
Cobb (05-17-2014)
Old 05-17-2014, 10:17 AM   #3 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Yes and no. On carbs, its to keep the velocity up at the throttle plate. On efi this isnt needed since fuel isn't added there.
Read this
AutoZine Technical School
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following User Says Thank You to Superfuelgero For This Useful Post:
Mista Bone (05-21-2014)
Old 05-17-2014, 03:07 PM   #4 (permalink)
Some newer engines don't even have a throttle plate anymore, relying only in the valve timing for that matter.
Old 05-17-2014, 06:47 PM   #5 (permalink)
I know the early water cooled vws had a secondary throttle that opened up at like 75% throttle. With its CIS injection system you can feel and hear it when that secondary opened up. VVVvvvrrrroooooommmmmmmm.
Old 05-18-2014, 04:47 AM   #6 (permalink)
An uncle of mine had a Brazilian Volkswagen Pointer GTi, basically a rebadged Ford Escort with a Volkswagen EA827 engine, and I don't remember it having a secondary throttle plate. But I do remember some carburettors which featured a dual-stage throttle, such as the Weber 450, locally known as "mini progressivo".
Old 05-18-2014, 09:40 AM   #7 (permalink)
Actually they do have throttle plates, but they're not used in normal operation. They are there for limp-mode and possibly cold start.
Old 05-18-2014, 09:54 PM   #8 (permalink)
Cool
Old 05-19-2014, 07:59 AM   #9 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
The quadrajet that came factory on my Monte Carlo used a similar setup with 2 small primaries that were good for easy cruising and 2 BIG secondaries for when your foot got heavy. Others with better tuned engines than mine have reported getting close to 25mpg highway. Best I ever saw was around 18.
I don't think multi-carb intakes work in the same manner. Usually a dual quad setup has a runner dedicated to each port on the carbs. However, a stock 6-pack intake might use the 2nd and 3rd carbs in progression to keep up with needed power...not sure how exactly the worked though.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 05-19-2014, 10:10 AM   #10 (permalink)
I'm thinking that a properly tuned American small block v8 powering a relatively light weight vehicle, such as a small pickup or mid sized RWD car, should be capable of low 30's mpg. Of course there are many many variables that would have to be sorted out, and building one of these vehicles for FE is nearly anathema to the whole point of putting an American v8 into a lightweight car....but I don't really see why we couldn't haul mass while growing grass.
