10-06-2022, 01:00 AM
#111 (permalink)
Ecomodding Apprentice
It seems that member title is awarded by post quantity not content...
10-06-2022, 09:02 AM
#112 (permalink)
You might change it to some personal message like I did but I forget how. It's in the User CP but could be a minimum amount of posts and I have found a lot of options here are browser dependent. Worse case use chrome as a default.
10-06-2022, 11:48 AM
#113 (permalink)
'thumbnails'
Originally Posted by Nathan jones
N.b And I'm not a Master ecomodder, who changes this??!!
* You'll be a 'master' soon enough!
* With the two images and 'qualitative' results:
It seems like the left image should depict a 'full' square-back wake, encompassing the entire rear of the structure.
The image to the right seems reasonable enough to a point.
The separated flow would arc down along a virtual 'golf ball' path, then, when it reached beyond 22-degrees of downslope, 'explode' into turbulence.
10-06-2022, 01:04 PM
#114 (permalink)
I'll repeat the question.
Is the ground plane to the left? Is it a centerline section? What gives?
10-06-2022, 03:10 PM
#115 (permalink)
wake
the wake for the shape on the left should look like this,
http://https://ecomodder.com/forum/m...here-money.jpg
10-06-2022, 04:11 PM
#116 (permalink)
Thanks, I tried but it means filling stuff out, when I've got time I will do it
10-06-2022, 04:13 PM
#117 (permalink)
Not everything is free. Try creating your own cfd enviroment, model some ideas and share them around
The Following User Says Thank You to Nathan jones For This Useful Post:
10-06-2022, 04:24 PM
#118 (permalink)
ground plane
1) The ground plane is out of sight, below the two images.
2) Flow is from the left, to right.
3) It may be 2-dimensional flow. Don't know.
4) For the left image, it's right ( downwind ) surface should be in total turbulence.
5) It's similar to the original Ahmed body on stilts, from around 1982.
#119 (permalink)
Thanks, but the hardest work was not done by me. I just used it for my car, and I think they do work for already laminar flat areas.
A small improvement, surface area, mass and driving style still hold far more areas for increased efficiency.
10-06-2022, 04:39 PM
#120 (permalink)
'for already laminar areas'
It does seem to be the case.
The only explanation I can come up with is that, the dimples 'DO' act as some form of VG, creating a lower local pressure along the 'boundary'.
With respect to the Mythbusters Ford sedan, they were able to induce the turbulent boundary layer to remain attached a bit better, minimizing the existing separation bubble, allowing enhanced flow reattachment, with higher pressure at the inevitable separation line.
Base pressure was slightly increased.
Pressure drag decreased.
Total drag reduced.
