Old 03-25-2010, 02:39 PM   #1 (permalink)
New bug, .38 CD why?
Title pretty much says it all,
For being round and what looks fairly aero, it isn't. Could it be the back wake creating most of the drag?
That doesn't seem like it would have much drag, does it?
cant post images... need 2 more posts
The link states that the rear bumper is where the flow is disrupted, and that causes the lift and severe drag as well.
Old 03-25-2010, 02:56 PM   #2 (permalink)
Think it is the rounded rear part that is detrimental to it's cd.
Old 03-25-2010, 03:29 PM   #3 (permalink)
Why? The Bug is a fashion statement, not an aero one. That pretty much says it all.
Old 03-25-2010, 03:32 PM   #4 (permalink)
I thought that the new Bug had a Cd of 0.45? The curve in the rear is way too steep. I doubt it has attached flow as far down the back as the picture shows...
Frank Lee (03-25-2010)
Old 03-25-2010, 03:35 PM   #5 (permalink)
I love drawings with arrows that purport to show airflow. :heart:
Old 03-25-2010, 03:50 PM   #6 (permalink)
.38
The New Beetle is short.It has a very low fineness ratio.While it has good penetration,once it gets to the frontal area cross-section,the curves rapidly approach those that cannot support attached flow,creating a significantly large wake,'poison of mpg'.
For performance,VW/Porsche/Audi squashes this shape down to create the Audi TT.
Old 03-25-2010, 04:21 PM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
In this case, the sooner the airflow detaches the better.
EDIT: The following in red isn't exactly true, see post #10 for details.
I saw a chart somewhere (can't find it right now, grrrr). Pretty much it showed that as the rear angle gets steeper (starting from 0°=flat) lift decreases until 12°-14°, then it increases again until 26°-28° when airflow detaches and lift goes down again.
So, if you can find the spot where the tangent is 12° and make a small "step", then the airflow will detach there, reducing lift at the best point. Many new cars already have this small "step" around the top of the rear window.
If you extend this "step" into a Kammback, you keep the angle right while reducing wake area, and keeping Aerohead happy at the same time
Old 03-25-2010, 04:23 PM   #8 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
for good aero you basically want a teardrop shape with a long tail. less ideal but still good you could have a shorter shape with sharp rear edges that allow for a clean sepparation of the airflow.
the beetle has none of this, the air separate very early and will become turbulent,
also the wheel wells will cause the air to sepparate and not reattach to the body.
i'd assume the air starts to sepparate much sooner, i think at the top of the rear window, and also the wheel fairings will greate much more turbulence than the image shows
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 03-25-2010, 06:44 PM   #9 (permalink)
Well the link shows video of the tuft testing, and it does look connected up to the end of the trunk.
Old 03-26-2010, 10:19 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
OK, I looked for the chart and found it. I was a little off, I got angles right, but mixed up lift (Cz) and drag (Cx). At my age, it's good I remember anything
Here are two charts, they are from Piechna's book. The data is compiled by the author from a few sources.
The first chart shows how drag first decreases, then increases, and finally airflow detaches, with the rear angle getting steeper.
The second chart is lift. When the roofline of the vehicle is flat lift is actually negative (=downforce). It grows linearly as the rear angle steepens, zeroing around 6°-7°, then abruptly falls to almost zero after 30°.
ID:	5852   Click image for larger version
The Following 4 Users Say Thank You to Piwoslaw For This Useful Post:
aerohead (03-26-2010), ChazInMT (12-18-2010), dremd (03-26-2010), razordave (09-14-2023)
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
[aero-mods(aft-body streamlining/boat-tails)Part-3 History/Timeline cont'd aerohead Aerodynamics 10 08-13-2010 12:50 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 10:45 PM
