Old 04-11-2016, 01:41 PM   #1 (permalink)
Black Ice - '01 Volkswagen Jetta TDI GLS
90 day: 52.07 mpg (US)
Black Ice v1.9 - '01 Volkswagen Jetta GLX
90 day: 43.74 mpg (US)
SuperSonic - '13 Chevrolet Sonic LT
90 day: 38.78 mpg (US)
New Tire Shopping
Hi all,
I have been shopping for some new low rolling resistance tires for my 01 Jetta TDI and I have decided to go with the Bridgestone Ecopia EP422 Plus. Now it comes down to what size to buy. Now stock my Jetta has 195/65r15 and I want to be more efficient than that so I want to go narrower and taller. Well, tirerack.com has options that are narrower (175/65r15) and taller (205/70r15) but no options that are taller AND narrower... So here is my question: Should I go with the taller tires that will lower my cruising RPMs or should I go with the narrower tires that will have a lower rolling resistance? For comparrison the tread width on the 205/70r15 is 5.9" and 20lbs per tire and the tread width of the 175/65r15 is 5.1" and 17lbs per tire.
Any help is appreciated, thanks in advance!
Old 04-11-2016, 02:31 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
im a fan of taller if your do a lot of freeway driving.
Lower weight is better for a lot of around town
you need to show:
original
weight, overall diameter, width.
taller
narrower
I don't see the 175 at tire rack so I cant really give you a good answer
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-11-2016, 02:37 PM   #3 (permalink)
Here are each of the tires specs
ID:	19902   Click image for larger version
ID:	19903   Click image for larger version
The Following User Says Thank You to shantiwitt For This Useful Post:
Joggernot (04-12-2016)
Old 04-11-2016, 02:45 PM   #4 (permalink)
mcrews's Avatar
thanks!!!!!
sO the tire effecencnce is the same for both.
and the narrow tire is just 1/2 an inch narrower and 1 lb lighter. (less than 5%).
the taller tire is 2lbs heaveier and slightly taller than 5%
I think it will depend on the mix of driving.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-11-2016, 03:06 PM   #5 (permalink)
I do mainly highway (50 miles each way to work) So I ordered the 205s. Thanks for your help!
mcrews (04-11-2016)
Old 04-11-2016, 03:19 PM   #6 (permalink)
mcrews's Avatar
you are very welcome!!!
I LOVE tirerack!!!!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-11-2016, 03:21 PM   #7 (permalink)
Same, they already called me to confirm that I wanted oversized tires
Old 04-11-2016, 03:22 PM   #8 (permalink)
mcrews's Avatar
btw,
I upsized on the infifnti Q45 and got a nice little bump in mpg on the road!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-11-2016, 03:24 PM   #9 (permalink)
mcrews's Avatar
hey, real quick. Check the clearance at the top of the tire to the bottom of the strut tower. you need just over 3/4 of an inch.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-11-2016, 03:26 PM   #10 (permalink)
My snow tires are 215/60-16 (had them from my old subaru) and they fit no problem, the ones I just ordered are .2 inches taller than those so I should be fine.
