05-10-2016, 10:57 PM
Makes me want to become a truck driver.
05-11-2016, 11:27 AM
Their claim of 1,200 mile range with a 320kWh battery puts the energy consumption at ~267Wh/mile - which is better than many EV cars. That is a little hard to believe.
Edit: it is a hybrid, and it has a turbine generator. So, it uses an unknown amount of fuel to go the 1,200 miles.
05-11-2016, 01:44 PM
Rat Racer
Diesel-electrics have been doing quite well in long distance heavy haul applications for some time now.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
05-11-2016, 01:51 PM
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
150 gallon fuel tank for CNG
The Following User Says Thank You to seifrob For This Useful Post:
05-11-2016, 03:53 PM
This is being discussed on Sheppard's AeroTruck thread.
The technical issues of a gas turbine charging a battery pack is questionable from an efficiency standpoint. It does allow a small and light weight power pack to charge a very large battery pack. But, does a gas turbine which has near double the fuel consumption on a mass/power/time scale of a modern diesel engine have the ability to haul 80K pounds of freight the stated 1200 miles without plug in charging? I really don't think so. Some simple math doesn't think so.
One interesting claim from the Nikola website is their procurement of natural gas wells to provide 1 million miles of free fuel to the first 5000 buyers. This would certainly offset their premium cost over current top Class 8 tractors.
I feel Sheppard's approach is far more practical now and in the near future. If you take the AeroTruck and use a smaller 11-12 L diesel engine with a reasonable electric boosting drive, you get the best of both worlds in that you can cruise on diesel engine power alone in flats and low loads and still have excess stored power to drive uphills with the ability to regain some of that energy on the downhills. Such a truck could happen NOW.
05-11-2016, 04:47 PM
Just cruisin’ along
I'd sign up to try one. If anyone here can get press loaners, I have the CDL!
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
05-11-2016, 06:05 PM
A gas turbine can be more efficient then a diesel when used as a powered for a generator. That is how I read this. The electic motors at the wheels are powered by a battery. The CNG turbine just trys to keep the battery charged. In 1200 miles both the batteries and the CNG is empty and it needs charged and refuled. The driver would be at his limit anyway before that point. Many heavy trucks are used less then 500 miles and may be able to go pure electic.
As pointed out, this is how a locomotive works but also how a submarine is powered.
05-11-2016, 08:01 PM
#9 (permalink)
The Rankine cycle turbine can be more efficient than a diesel piston engine but emissions standards for NOx and manufacturing costs have been barriers in the past. The concept has merit even if CNG is not yet available at every truck stop. We have a local station for CNG in Sayre, PA and fleets in the region have their own fueling facilities. GE has put out bids for injectors to use CNG for their locomotive engines. Starting and braking are the high torque operations that benefit from electric motors. Hybrid pick up trucks may be in the offing too. Farmers and construction fleet operators are very cost conscious.
05-11-2016, 08:35 PM
#10 (permalink)
Crown Vic - '99 Ford Crown Victoria Base (P74) 90 day: 24.1 mpg (US) Turtle - '98 Subaru Outback Sport 90 day: 30.53 mpg (US)
'99 Crown Victoria
'97 Impreza 2.2, 5-speed
'98 Impreza Outback Sport 2.2, 5-speed
'05 Outback 3.0R (wife's)
The Following User Says Thank You to The_Jed For This Useful Post:
