Old 06-26-2009, 08:49 AM   #11 (permalink)
OBDuino32k now supports tank size and gas price in gallons. It's actually saved as litres and converted back to gallons when again displayed or used, so there may be a small rounding error involved.
When entering gas prices, litres are in cents(XX.X), gallons are in dollars (X.XXX).
Old 06-26-2009, 04:34 PM   #12 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Why are liters in cents? If gas is $4.000/gal, it is $1.057/L, which doesn't fit in XX.X cents.
Old 06-26-2009, 05:04 PM   #13 (permalink)
Good point. Currently where I am, gas is usually under a buck per litre and we currently count gas prices in cents per litre, not parts of a dollar.
The $1.057 a litre will display as 105.7 which is a little strange, but it works.
We could change the format easily enough on the fly (if value is 100 or greater display as dollars, else as cents...)
Old 07-23-2009, 02:46 PM   #14 (permalink)
I just checked in a new version of OBDuino32k (version 157.)
OBDuino now features a new menuing system so that you can edit and redit the parameters in any order you wish (including just exit). It also will not bother to save if no changes are actually made.
Also, I have removed the flicker from the LCD.
Auto transmission with the manual shift feature ScottC33 Hypermiling / EcoDriver's Ed 5 06-17-2009 07:32 AM
Interview request for ecomodder in Tampa Bay area MetroMPG EcoModding Central 0 03-04-2009 08:46 AM
Used Car Feature: 2003-2008 Pontiac Vibe / Toyota Matrix (35.5 MPG) SVOboy EcoModder Blog Discussion 6 11-24-2008 07:13 PM
Feature request: Maintenance Diary in the Fuel Log Joe_Bloe Forum News & Feedback 1 10-05-2008 11:03 AM
