Old 07-29-2008, 09:19 PM   #11 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
The TDI guys swear by the Pella.
I think the effectiveness depends on the design; some engines will work better than others.
I fI was going to spend $65 + shipping then I'd just splurge for a bypass filter and quit Changing oil. <- Guess what's on my TDI :-)
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-29-2008, 09:49 PM   #12 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Pontiac Firefly 3dr
90 day: 40.08 mpg (US)
So for $65 you get a bucket and a length of vinyl tube?
Old 07-29-2008, 10:50 PM   #13 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Ive never thought too highly about sucking the oil out the dipstick tube. Use the drain plug, then any gunk in the oil will flush out with it.
My cars have always been too low for ramps, so rather than jack it up and screw with stands, sometimes I just drive it up onto a couple 2x6s and that gives enough clearance to get under it to change the oil.
Winter daily driver, parked most days right now
Summer daily driver
Old 07-29-2008, 11:27 PM   #14 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Honda Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
They're primarily for marine applications, I bought one and used it on my car when I overfilled the engine with oil (compensating for a leak), then fixed the leak.
In hindsight, I guess I could have just pulled the drain plug and collected the fresh oil into something and then poured the proper amount back in but for whatever reason this device seemed easier when I ordered it.
As far as sediment or whatever in the bottom of the oil pan, if you have to worry about that I think you probably need a better filtration device.
If someone wants to buy one for half off, let me know.
Old 07-29-2008, 11:39 PM   #15 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
Yes, new Mercedes Benz autos require a vacuum evacutator due to all of the skid plates under neath, its dreadful. I use one for my 1985 300D Turbodiesel. I can get the oil plug out from the bottom without jacks but I like staying clean and I spend enough time under the car already.
To top it all off most Mercedes Benz engines use a drop in type of filter element.
its to the right, the canister looking dealy. All I do is unbolt it, grab a plastic bag and flip it into the bag, no mess at all. Then I pump the mity vac liqui vac and let it sit for 20 minutes while it sucks all of the oil out. then use the factory oil funnel aka the oil filter housing and fill it with 8 quarts of heavy duty truck and bus oil then drop in the filter and bolt it up. No fuss or mess.
Old 07-30-2008, 01:21 AM   #16 (permalink)
EV OR DIESEL
And a Vacuum pump
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 07-30-2008, 01:29 AM   #17 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
And Tony, if you have any questions about how to use the jack, just ask the cat. Looks like he has thoroughly studied the instructions on the box.
At least he's changing the oil in the comfort of his livingroom. Why didn't I think of that?
Old 07-30-2008, 03:00 AM   #18 (permalink)
Schwartzejetta - '00 Volkswagen Jetta TDI GL
90 day: 52.87 mpg (US)
Originally Posted by atomicradish View Post
You still have to get under the car to change the oil filter...
On my car (VW Jetta), the filter's up top. I've seen these sort of extractors talked about on TDIclub's forums - the main brand bandied about is a Pella Oil Extractor.
Up here in Canada, I've seen the same sort of device at Princess Auto... I've been thinking about getting one, since a few of us at my workplace will occasionally do minor car work (like oil changes) after hours on our vehicles.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 07-30-2008, 02:09 PM   #19 (permalink)
wikityler's Avatar
Originally Posted by dremd View Post
And a Vacuum pump
Vacuum pump is not needed, just let the tube siphon out the oil.
Old 07-30-2008, 02:51 PM   #20 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Originally Posted by cfg83 View Post
MetroMPG -
Wait, I'm confused. I thought the investment *was* the cat. Everyone knows that cats are masters at changing oil. My Siamese could change my car's oil in 20 minutes flat. Not bad for an 11 lb cat.
Am I missing something?
CarloSW2
You are missing something. You need a few more cats and open a business, Purfect Oil Changes.
I just hope you have all the right papers for your cat or he might get deported and you fined. Remember what happened to Kathy Lee Gifford and the sweat shop?
Honda...the economical, renewable resource.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Synthetic Motor Oil Change Interval trikkonceptz Off-Topic Tech 15 06-11-2008 10:08 PM
3000 mile oil change is a myth! SVOboy Off-Topic Tech 15 02-14-2008 03:43 AM
