06-06-2009, 04:18 PM
This thread is in the EcoModder Project Library |
Phil Knox's aero-modded 1970 VW van
The Following 3 Users Say Thank You to aerohead For This Useful Post:
06-06-2009, 05:29 PM
Wow, that's a huge improvement. I wonder how much of the improvement is from the boattail, and how much from the belly pan
06-06-2009, 06:05 PM
I'm betting the belly pans didn't help much. - those vw campers had an almost smooth underbelly anyways, same as the beetles.
Would lowering it have helped at all?
06-06-2009, 07:39 PM
That is over a 25% reduction in Cd! That is substantial. I thought I was doing good with a 10% reduction in Cd with the aerocap for pickups!
No wonder you know a little about aerodynamics, you have been doing neat stuff for 30 years now!
Thanks for sharing with us,
Bondo
The Following User Says Thank You to bondo For This Useful Post:
06-06-2009, 08:54 PM
Did you make any changes to permit engine cooling? Didn't the original design use the low pressure at the back to draw air through the engine compartment, exiting through vents on the back of the van?
Thanks for posting this, Phil.
06-06-2009, 11:50 PM
VWs exhaust the cooling air underneath
06-07-2009, 02:21 AM
is not covered in bees.
That really is an amazingly effective improvement. Thanks for sharing it with us!
06-07-2009, 10:05 AM
Basjoos Wannabe
I suspect some of the increase in efficiency was helped by it having a really bad .455 cd. When you start bad, any improvement is substantial. I suspect if I were to do the same with my van, which already has a cd of .35, I would be lucky to net the same percentage decrease, which would be a .26
The work is indeed nice and clean, though. Reminds me of an Airstream travel trailer. Looks like the rear tailgate was completely inaccessible; wouldn't that be a problem for a VW camper come tune up time?
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
06-08-2009, 02:56 PM
#9 (permalink)
how much
Sorry,I didn't expect to be back at the computer 'til next weekend and I don't have my materials with me.When the testing was done,everything was done as a "kit"and I had to rely on published relationships to help sort it out.The reason for the boattail,was that from the published literature it promised significant improvements.----------- I'll bring my papers next time and post what I deduced.
06-08-2009, 03:07 PM
#10 (permalink)
belly
My van was just the standard transporter and lacked all the Westfalia equipment,which I mimicked.The original underside was a deep,ladder-type frame with deep recesses.According to R.G.S.White's Method of Estimating Drag Coefficients,it had one of the worst undersides in the industry.After studying Aerodynamics of Road Vehicles by Skybor and Rylski,I was convinced that my VW was a premium candidate for the bellypan.--------- Lowering would have certainly helped,although would effect utility for the places I'm likely to go( I still have the van).Lowering any vehicle effectively increases its fineness ratio,reduces frontal area a smidge due to cloaking of the tires,and also lowers C.G.,all good things.
